Camry Rear Strut Install - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 01-09-2007, 05:18 PM   #1 (permalink)
View Macgarth's Photo Gallery
I have a '00 camry and recently the rear strut went on her. Picked up the part today and was going to work on the install this weekend. Just wondering if anyone else has tackled this before and if they had any tips or info to help me out!
Macgarth is offline   Reply With Quote
Old 01-12-2007, 03:51 PM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $395785
View RningOnFumes's Photo Gallery
Try the camry section stickies..I know there are a couple of diy instructions laying around.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 01-12-2007, 04:47 PM   #3 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Not 100% positive on Gen4's, but on Gen3's (92-96), you have to pop out the back seats, take out the side supports, and pull off the rear deck. Then you can gain access to the bolts holding the struts in place. To remove the struts, you'll also need a hex key and wrench to disconnect it from the endlinks. If you plan on just replacing the strut and reusing the original strut mount/spring/boots etc., you'll need a spring compressor and likely an impact wrench to get the top mount nut off.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 01-12-2007, 11:06 PM   #4 (permalink)
Thanks guys. I picked up a service manual this week to check out the procedure. I also searched the site and could only find gen3's. But it works about the same for the gen4. Back seat comes out, take off a few bolts and what not. Bolts came out good, considering all the rust our cars up here get from salt and winter. Removed the entire strut and put a diff one in. Really wasn't too bad, took about 1.5hrs, and most of that was getting the seat out
Techna-fit Brake/Clutch Line Group Buy: All Makes/Models raptorracing Supporting Vendor Sales 230 08-27-2007 01:22 AM
GPS Antenna Location on Gen 6 hybridamp 5th & 6th Generation (2002-2006 & 2007-2011) 2 08-30-2006 01:13 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 07:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-11-2006 12:45 AM
Changing out strut mounts and spring bumpers - Advice needed (4th Gen Camry) Bob_98SR5 Camry & Solara Lounge 6 03-01-2004 08:17 PM
