Warped rotor shudder to 60-70mph shudder...? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 04-01-2007, 08:58 AM   #1 (permalink)
View madmurr's Photo Gallery
Question Warped rotor shudder to 60-70mph shudder...?
Hi all, I own an '01 Highlander V6 w/ ~72k miles.
On long trips, I noticed that the brakes would shudder so I replaced the front rotors and pads (come to find out that the inner right front rotor was scored quite badly). Now there's a shudder whenever I'm going ~60-70 mph...??? I did not switch the tires from left to right and vice versa and I seriously doubt the balance went out just from taking them off and laying them on the ground. The tires are Michelin XC LT4 225/70R16 and are in excellent condition w/ plenty of tread left.
But yet it seems I either have a wheel balance or an alignment problem...that I didn't have before I changed the front brakes...any ideas?
Any insight would be much appreciated.
Thanks,
Madmurr
madmurr is offline   Reply With Quote
Old 04-01-2007, 05:00 PM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $903564
View humanoid's Photo Gallery
Check the torque on the lugnuts, make sure they are done to specs. Not sure what it is on the Highlander, but on my Taco it 85 ft/lbs.
This is my sig.
humanoid is offline   Reply With Quote
Old 04-02-2007, 12:26 AM   #3 (permalink)
Thanks for the reply, I will take it into a shop to have that checked as I don't have a torque wrench! I'll post again after...
2002 Toyota Highlander V6 2WD
2005 Honda Accord EX-V6 4-door
Old 04-02-2007, 06:26 PM   #4 (permalink)
View toyomoho's Photo Gallery
Swap out the spare with the front tires one at a time. Check for excess front bearing and tie rod play. Perhaps the new rotor(s) are out of balance. Suggest doing these items before an alignment.
Old 04-03-2007, 06:37 PM   #5 (permalink)
Took it in, turns out I had the lugnuts WAY too tight, but that wasn't the fix. Went back today and had the front tires balanced, now all is good.
Thanks for the help!
Madmurr
Edit: BTW, my spare tire is one of those tiny things, not regular size.
Edit 2: The torque spec for an '01 Highlander is 76 ft/lbs (for those searching)
A/T: Found a way to reproduce 20-30mph shudder 91MR2quickNA 2nd Generation (2005+) 6 02-19-2007 12:00 PM
Consumer Reports reviews versions of the Sebring, Optima, Altima, G6, and Aura IFCAR General Discussion 0 02-05-2007 08:21 PM
