Brake components - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 04-07-2007, 08:39 PM   #1 (permalink)
Feel the vibe.
vibebreaker's Avatar
View vibebreaker's Photo Gallery
Brake components
I drive a 2001 Corolla S.
Currently running on brembo oem replacement rotors and hawk hps street brake pads with rubber flexi lines.
In about 5k miles, I am looking to replace my front rotors, pads and switch all brake lines to ss braided (already got em from techna-fit). I've also switched brake fluids to ATE Super Blue Racing.
I have been eyeing the powerslot cryo-treated rotors and the hawk hps race pads.
Am I going overboard with race pads? Should I just stick with street pads?
vibebreaker is offline   Reply With Quote
Old 04-08-2007, 10:23 AM   #2 (permalink)
on full afterburner
PhatRoyale's Avatar
Gameroom cash: $1191747
Where you drive the car most will largely determine what type of brake pad you will need.
Is it going to be a car that's tracked every weekend? A daily driver? Or a garage queen?
More info is needed.
Old 04-08-2007, 02:21 PM   #3 (permalink)
Feel the vibe.
it's a daily driver mostly on highway and there are some times that i have had to stop abruptly..
Old 04-08-2007, 11:00 PM   #4 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
well for a daily driver you probably will hate to keep changing pads with slotted rotors slicing and dicing away at the meat of brake pads, and race pads will probably be noisy and extremely dusty.
Basically your current setup is good enough for any corolla once you add the SS lines. If you can set off your abs, that's telling you that your braking system has more than enough force to reach and exceed the maximum friction between your tires and the road.
The products your suggesting to purchase would not be of benifit to you. I've driven my dad's 01 CE without ABS and with stock everything, including rear drums, i can lock up them wheels easily. The BEST investments you can make for your corolla is keeping up with maintenece for all brake and suspension parts, as well as getting GOOD tires. Good meaning a tire with a government traction rating of AA.
nodrogkam is offline   Reply With Quote
Old 04-08-2007, 11:37 PM   #5 (permalink)
Feel the vibe.
my car doesn't have abs but i guess i'll just have the ss lines installed then
thanks
Old 04-08-2007, 11:58 PM   #6 (permalink)
nodrogkam's Avatar
oh i thought the S came with ABS.
Anyways, the ss lines should give you better brake feel and i think u will be happy with the results. If not, then consider the other upgrades.
Old 04-09-2007, 01:21 AM   #7 (permalink)
on full afterburner
PhatRoyale's Avatar
Even OEM pads would be suitable for your application.
I would not get race compound brake pads for the fact that they are meant for the track only and will require a few HARD stops before they reach proper operating temperature. Under normal driving conditions, and when cold, they will require LONGER stopping distances than normal street compound brake pads, which can be dangerous if you suddenly need to stop on cold pads on the highway.
Like nodrogkam said, keeping up with maintenance should be your first priority.
Old 04-09-2007, 02:13 PM   #8 (permalink)
Feel the vibe.
well i already have AA tires. the only time i'll have to install my ss lines are on friday april 20th. i have a 300 mile drive later on that day as well so i'm gonna see how it'll go.
Old 04-09-2007, 02:34 PM   #9 (permalink)
nodrogkam's Avatar
well, u've done pretty much all you can do! good job!
I should add that while your going to bleed your brakes anyways to switch the lines, you might as well bleed more of it out so you can put some fresh fluid in. Fresh fluid has a higher boiling temp so it'll be better, plus the fluid will be cleaner, better for the lines.
Old 04-09-2007, 02:52 PM   #10 (permalink)
Feel the vibe.
i just recently changed to ATE super blue racing fluid about 200 miles ago hehe
Old 04-09-2007, 02:53 PM   #11 (permalink)
nodrogkam's Avatar
good man.
hopefully you still have some left. U'll need at least 1/2 of a small bottle of fluid for this job.
Old 04-09-2007, 02:59 PM   #12 (permalink)
Feel the vibe.
ah crap, i left the bottle back home!!! hmm at least i have time to get a bottle...
94 Camry brake warning light eaglemtn 3rd & 4th Generation (1992–1996 & 1997–2001) 24 09-16-2011 06:07 PM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-30-2008 12:33 AM
Brand new brake pads, brake pedal still bottoms out!! izekat Tercel, Paseo, Starlet, and Sera Forum 6 06-26-2005 12:35 PM
Rear brake squeal on an '03 LE (drum) Corollaized Archived Corolla threads 0 10-15-2004 08:05 PM
gen2 brake light stays on... help... please.. busted_ride 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2004 05:56 AM
