07 Camry Alloy weights? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 04-13-2007, 02:01 AM   #1 (permalink)
View 07 SE's Photo Gallery
Gen6 07 Camry Alloy weights?
Interested in upgrading the tire/wheel package on an 07 SE I4...
But of my concerns is the weight savings if any I'd have going aftermarket vs. the alloys already on the SE...
Eye is on 18", so the savings if any might be negligible, but I suppose it'd be a waste to get anything heavier...merely for looks...since I went I4 to $ave on gas in the 1st place...and in my opinion my I4's underpowered for my taste to begin w/....any idea what the stock Camry alloys weigh....
TIA.
PS already tried SEARCH and GOOGLE....
07 SE is offline   Reply With Quote
Old 04-13-2007, 03:11 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
Do you have the capability to take one off and weigh it? Then see if you can find the weight of the tire that is on there on the manufacturer's web site or on tirerack and subtract it.
2007 Camry 2.4L 5M
Old 04-18-2007, 12:05 PM   #3 (permalink)
the Maxima guy...
Chunger's Avatar
View Chunger's Photo Gallery
I would look for a specifically low weight aftermarket rim. My 18x8" OZ Superleggeras (18 lb) with tires were about 4 lbs lighter than the factory XLE/TCH wheel/tire weight. Keep in mind that the weight on bigger rims will be further away from the axis so that plays a factor as well as the overall weight. Try to find a wheel around 16-18 lbs each. My Lowenhart LH5 (18x8.5) are 28 lbs each! You will feel it in acceleration and braking...
Loaded TCH with 4300K and 235/45/18s on OZ Superleggeras... still getting 38mpg...
Balances out nicely with my SC'd Maxima at 18mpg
Chunger is offline   Reply With Quote
07 Camry Spare Tire ??? so40 5th & 6th Generation (2002-2006 & 2007-2011) 33 10-17-2011 06:41 AM
Traded in my 05' Camry for an 07' Avalon CygnusX1 5th & 6th Generation (2002-2006 & 2007-2011) 1 01-08-2007 03:28 AM
07 Camry Loss of Power after 800 Miles kevtsai 5th & 6th Generation (2002-2006 & 2007-2011) 2 11-29-2006 07:50 PM
My father might buy an '07 Camry! 84Cressida General Discussion 17 08-08-2006 07:29 PM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 07:27 AM
