Will they fit ? ? ? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 04-14-2007, 07:19 PM   #1 (permalink)
View michoujordan76's Photo Gallery
Will they fit ? ? ?
Hi all,
I have a chance at a set of alloys from a 1987 Honda CRX that measure 14 x 5J with a 4/100mm stud pattern. According to my google research, the centre bore is 56.1 whereas my Echo's is 54.1 - do you think they will fit? Will they vibrate at high speeds? Will my 175 65R14 tires be ok?
Thanks!
michoujordan76 is offline   Reply With Quote
Old 04-16-2007, 10:27 AM   #2 (permalink)
View kyle@tirerack's Photo Gallery
Both cars have similar offsets and we have used the same part numbers of certain aftermarket wheels on both cars. If the center bore of the actual wheel is larger you could likely use with a set of centering rings. There are still things such as brake clearance that I am unsure of and that could vary from wheel to wheel so a test fit would be best. The tires you have will fit the wheel without issues. Give me a call if you want to discuss the details.
kyle@tirerack is offline   Reply With Quote
Wheels that will fit! Dseldown 89-95 Toyota Pickup/Hilux 3 02-07-2006 05:51 PM
blinkers dont fit!! Mayne Event Camry & Solara Lounge 6 10-14-2005 07:11 PM
Would a camry motor fit a sienna without any mods? tousi Camry & Solara Lounge 22 10-04-2005 02:30 PM
Witch engines fit the Sienna? tousi 1st Generation (1998-2003) 1 09-26-2005 11:14 AM
HELP! will these rimz fit pk_kk Camry & Solara Lounge 5 06-06-2005 03:42 PM
