Best tire for these specs? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 04-20-2007, 02:18 PM   #1 (permalink)
Archosman's Avatar
View Archosman's Photo Gallery
I've got a '06 LE. I've been trying to figure out my best options.
I would like to go with a 18x8.5 with a 35mm offset. I'm curious what would be my best tire choice. Tirerack says that 225/45/18 will work. I'm just curious if that will rub. Thanks.
Archosman is offline   Reply With Quote
Old 04-21-2007, 08:40 AM   #2 (permalink)
View kyle@tirerack's Photo Gallery
The 225 gets aggressive on the rear with 8" wide wheels and 35 mm offset. I have notes that the 8" may require rear fender modifications with the 225 tire so the 8.5 would likely be the same. Give me a call if you want to discuss the details.
kyle@tirerack is offline   Reply With Quote
Old 04-22-2007, 01:22 AM   #3 (permalink)
Archosman's Avatar
Would a 225/40/18 be a better choice then? I'm new to all this...
Old 04-23-2007, 07:12 AM   #4 (permalink)
The 225 40 18 would be shorter but I believe the width is the main issue. The 40 series also drops pretty low in regards to weight capacity. The wheel itself is pretty aggressive and will be pushing the tire towards the fender.
Old 04-26-2007, 03:29 PM   #5 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
225 seems kinda thin for an 8.5. Why not go 235/40/18
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Winter Tires & Rims on XLE (pics!) SuperGoop 5th & 6th Generation (2002-2006 & 2007-2011) 23 02-02-2007 01:11 PM
Is This A Good Tire? aduncan8434 2nd Generation (2005+) 27 01-29-2007 05:35 PM
Spare tire rubbing on frame John bigbooty 2nd Generation (2005+) 2 11-05-2006 08:38 AM
Tire help -- Run flats?? SnowCindy 89-95 Toyota Pickup/Hilux 18 10-28-2006 02:46 AM
What are the tire specs for Clints camry? MattSWE Camry & Solara Lounge 1 05-01-2006 03:02 PM
