Can I put 215/60r16 on avalon 1998? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 05-15-2007, 04:32 PM   #1 (permalink)
View rey123's Photo Gallery
HI!
can i install 215/60r16 offset 45 on 1998 avalon xls?
thanks
rey123 is offline   Reply With Quote
Old 05-15-2007, 05:14 PM   #2 (permalink)
View kyle@tirerack's Photo Gallery
We normally used a 215 55 16 which is roughly an inch shorter and close to the original equipment diameter. You may have to test fit one to be sure.
kyle@tirerack is offline   Reply With Quote
Old 05-16-2007, 11:53 PM   #3 (permalink)
kyle@tirerack Thanks for your reply
kyle@tirerack
If i'm going to use 16"
can I use 205 60 r16? on the avalon 1998 xls ( so i dont it the fender with the tire)
Wich is the best size to use with 16" rims?
Thanks
Old 05-17-2007, 09:10 AM   #4 (permalink)
205 60 16 would be fine in addition to 215 55 16 if you want a slightly wider tire. Normally we would recommend a 205 60.
Tires for Avalon xls 1998 rey123 1st Generation (1995-1999) 4 05-29-2007 07:36 PM
1998 Avalon A/C Issues ignoreme 1st Generation (1995-1999) 2 04-11-2007 10:47 AM
Avalon shows dent in Toyota quality sciguy0504 Toyota News 98 03-25-2007 11:49 PM
Does a 1995 Avalon and a 1998 Avalon have the same armrest? wuhukf 1st Generation (1995-1999) 2 05-23-2006 06:14 PM
Sunroof problem for 1998 Avalon toyzota 1st Generation (1995-1999) 0 04-27-2006 10:18 AM
