Replaced pads, brakes still squeaks? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 06-13-2007, 04:41 AM   #1 (permalink)
View nuron's Photo Gallery
To make it short, after I replaced the pads, my brakes still squeak from time to time. I noticed that it happens with the first inch of the pedal travel. Anymore after taht and the squealing stops. Could it be those little clips? I ordered a new set already .
nuron is offline   Reply With Quote
Old 06-13-2007, 10:58 AM   #2 (permalink)
the Maxima guy...
Chunger's Avatar
View Chunger's Photo Gallery
brake squealing is more annoying than anything else (especially since you know you have new pads). Mostly caused by debris between pads and rotor. Did you reuse the original brake anti squeal shims and also some anti squeal "goop" between them?
2007 loaded TCH with 4300K HIDs and 235/45/18s
2012 HiHy Limited
Chunger is online now   Reply With Quote
Old 06-13-2007, 12:49 PM   #3 (permalink)
Yeah I used the old shims, no 'goop' though...
Old 06-20-2007, 03:21 AM   #4 (permalink)
View jackie_ae's Photo Gallery
get a genuine Toyota brake pads. some squeaks are caused by the pads. then clean your rotors by sanding it a bit.
blog!
jackie_ae is offline   Reply With Quote
Old 06-20-2007, 10:10 AM   #5 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
well if it aint toyota it'll cause more noise (most likely). If you get Akebono pads though (they're basically same as toyota) then you'll be good. And sometimes its hit and miss.
but yeah antisqueel grease helps a lot too
nodrogkam is offline   Reply With Quote
Old 07-10-2007, 10:41 AM   #6 (permalink)
View proteus220's Photo Gallery
I have a "stupid" question about the antisqueal goop.
- If the goop is applied on the backside of the brake pad and shim, how does that prevent squealing? There are no "moving" metal on metal contact that should cause it to squeal when the brakepad clamps down on the rotor during braking.
Can anyone please shed some light on this? Or perhaps my way of looking at it is off.... Thanks for anyone's input
proteus220 is offline   Reply With Quote
Old 07-10-2007, 10:58 AM   #7 (permalink)
the Maxima guy...
Chunger's Avatar
the "goop" (and shims btw) absorbs the vibration of the pads in the calipers as it "glides" across the rotors during braking that would normally make noise...
2012 HiHy Limited
Old 07-10-2007, 11:06 AM   #8 (permalink)
Gameroom cash: $147537
The pad does move in the bracket. The piston will "slide" at the back of the pad. The rubber compound remove metal to metal and also act as vibration damper.
Brake squeal is due to bad rotor surface. bad break in or uneven pad material deposit.
Try this tonight. Wash the rotor after you park the car and after brake cool down. You'll see a layer of rust in the morning. Just drive normal. Repeat for a few days. Squeal should be gone.
Old 07-10-2007, 12:11 PM   #9 (permalink)
nodrogkam's Avatar
^ that probably wont be a long term solution. There are so many brands of pads out there and most of them can be used on various applications, but on some car combos' although it fits, it doesnt fit perfectly or is sized slightly differently, and that alone is enough to cause problems.
If you're working with all OEM equiptment its best to go OEM. U can play with aftermarket stuff and what not but ur always risking it.
Old 07-10-2007, 12:28 PM   #10 (permalink)
the Maxima guy...
Chunger's Avatar
Going OEM pads is fine for most people but if you want "better" performance certain aftermarket pads are the answer. Just be aware that not all "aftermarket" are the same (or even better than OEM). There are many great manufacturers out there. Sometimes the noise is not from the friction surfaces themselves...
BTW, aftermarket brakes doesn't always mean that you will have squeal. I have a 13" AP Racing BBK on my Maxima and it has ZERO noise...
2012 HiHy Limited
Old 07-10-2007, 08:20 PM   #11 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
Bout time someone said that. ALWAYS when you replace pads get the rotors resurfaced, if you dont your just gonna get squeeks!
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 07-11-2007, 09:39 PM   #12 (permalink)
nodrogkam's Avatar
my friends and i dont always resurface the rotors, esp the slotted/X-drilled, but we have no problems.
yes i relize people want more performance etc, but the oem braking system, if kept in pristine condition will do the job if the rest of the car is oem setup. Remember ur only going to stop as fast as your tires will allow, and fading or brake failure is not always caused by the pad.
Anyways no real debate here. If the pad, calliper, rotor combo doesnt work together, something is going to happen.
Old 07-24-2007, 03:40 PM   #13 (permalink)
I bought some of the Napa brand disk brake quiet stuff and the initial squeal is STILL there! I'm talking about the first couple inches of pressing the brake pedal and anything after that is quiet. I'll wait a couple days and see.
Is there a difference between OEM and aftermarket "OEM" Brake pads? YES! Daffunda 5th & 6th Generation (2002-2006 & 2007-2011) 9 11-12-2006 03:40 PM
Brakes, How are yours? Chazmanian 2nd Generation (2005+) 45 03-24-2006 03:18 AM
Brake Pads being replaced ComaSport4x4 2nd Generation (2005+) 0 02-10-2006 09:27 AM
Anti-squeal on brake pads... 97&02camryleI4 Camry & Solara Lounge 10 06-25-2004 12:01 AM
Brake Pads Eye8Pussies General Discussion 10 03-18-2004 06:37 PM
