What tires did you buy? They are possibly more aggressive than the ones that came stock with your Toyota. Usually, the stickier the tire, the louder it is. If your wheel is not balanced, you'll feel vibrations instead...not sure how they can figure out if it balanced in 5 minutes.
What size is the tire? Is it the same as stock? If not, the wider the tire, the gripper it is, and then your car will perform differently.
Just remember, not all tires will sound/feel the same. For instance, when you put on snow tires, it sounds like you're in a train....
