Originally Posted by CWS30D
Hi guys, I recently lifted the front of my 2007 Hilux SR5 4WD dual cab and it also buggered the alignemnt. WIth the factory camber pins I was not able to get any further adjustment and as a result ot has started to wear the outside edges off the tyres cause I only have negative camber. Are you aware of anyone in the USA that makes an adjustable camber pin as if these could be sourced and fitted it would solve the problem.
You must have excessive positive camber to eat the outside edge of your tires (or possibly toe-in). Negative camber / \ willl eat the inside edge.
You should be able to buy crash bolts, which are camber pins with more adjustment than the OEM ones.
