2002 Sienna slow leak - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 09-10-2007, 12:44 PM   #1 (permalink)
View ab257z's Photo Gallery
We have a tire that is losing about 2-3 pounds per day - no visible damage to either the tire or stock allow wheel. Had the tire remounted 3 times, and cleaned the wheel down to bare metal (can sanding the wheel with 180 grit sandpaper damage it?). No bubbles when put in a tub.
Could it be a bad tire or damaged wheel (both look in good condition)? Would it be OK to replace the two front wheels with steel wheels if it is a bad wheel - right now I plan to buy a new tire and see if it leaks on that wheel also.
Thanks for any advice.
ab257z is offline   Reply With Quote
Old 09-10-2007, 10:43 PM   #2 (permalink)
Toyota Nation User
4runnerracer's Avatar
View 4runnerracer's Photo Gallery
Have you tried checking the tire stem valve to see if it's tight or leaking? Spray some soapy water in the valve and around the stem and see if you have any bubbles.
01 Toyota Tundra Mods: Throttle Body coolant bypass - Differential breather extended - DRL disabled
4runnerracer is offline   Reply With Quote
Old 09-11-2007, 07:00 AM   #3 (permalink)
View kyle@tirerack's Photo Gallery
If no leaks appear to be visible, you could dismount and swap one of the other tires with this wheel. It is more work, but may allow you to determine if it is the wheel or tire before you start replacing either of the two.
kyle@tirerack is offline   Reply With Quote
2002 Sienna Sludge despite changing oil every 3k? wjchun 1st Generation (1998-2003) 16 05-12-2007 12:31 AM
2002 Sienna wheel fit 2004 Dodge Caravan? Jaspher General Discussion 1 11-18-2004 04:50 PM
All New Sienna is Here! 2000CamryLEV6 2nd Generation (2004-2010) 13 03-20-2003 12:52 PM
