Tire circumference and mpg's - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 10-03-2007, 10:32 AM   #1 (permalink)
View downwind4final's Photo Gallery
If I switch from a 215/60/16 to a 225/50/17 revolutions per mile increase by 9 (from ~795 to ~804) and would affect the speedometer by .75 mph. Would this affect gearing enough to noticeably impact gas mileage? This would also inaccurately increase the number of miles on the odo too, correct?
downwind4final is offline   Reply With Quote
Old 10-03-2007, 12:43 PM   #2 (permalink)
View kyle@tirerack's Photo Gallery
The formula below will help you determine the new RPM range that the vehicle will run at with the new diameter at different speeds. Just plug in the numbers with diameters and your current rpms at speed for the changes. This is a minimal change and I don't feel that you'll see a dramatic difference either way.
(Original Tire Diameter / New Tire Diameter) X RPM@MPH = New RPM @ actual MPH
This example is for 55 MPH
Example:
(27" / 32.5") x 2400 RPM = 1985 RPM @ 55 mph with new tires.
kyle@tirerack is offline   Reply With Quote
Old 10-03-2007, 12:50 PM   #3 (permalink)
Thanks!!
It comes out to ~23 rpm. I don't see that having any effect. It's about the same differece in overall diameter as a new set of tires and an almost worn out set.
