Taco rim/tire issue - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 11-15-2007, 11:09 AM   #1 (permalink)
View TRDXD45's Photo Gallery
Taco rim/tire issue
Originally posted this on the Tacoma forum and one of the moderators suggested that I post here. Any rim and tire experts out there that can help? Particularly with #2 below. Original thread is- TN Rim and Tire Expert???
Ok. here is the current set up in the front of my '05 TRD. 884 3" lift, billy 5100's (set at lowest setting), helo maxx 6 17x9 rims (4.5" backspace), and BFG A/T's in 285-70-17.
I decided to downsize the tires since i'm getting killed in gas mileage and the 285's rub the cab frame, so I went out and got 265-70-17 A/T's and took them to the shop yesterday to have mounted. Couple of hours later the shop called and said they had some things they wanted to show me before moving on.
1. Upper and lower ball joints- was told that if you drew a line connecting the two, the line should point directly to the center of the rim. On my yota, this is not the case. Told me this will cause a "bump steer" at higher speeds. Basically the wheel will jerk when going over a significant bump and if this is not fixed it could cause excessive wear on the bearings. I have noticed this on my current setup and IMO it is not a major concern...more of a nuisance. I'm thinking UCA's would fix but I just don't have the $$$ right now to get them. See #2 for alternate solution (according to the shop).
2. Rims are too wide causing lug nuts to not grab enough thread- Told me BFG recommends 7 or 8" wide rims on the 265 size tire. Mine are 9" and when mounted, the rims are too wide resulting in not enough lug protruding through the rim. When they cranked down the lug nuts, they found that they gripped only 4 turns worth of thread before tight. Toyota recommends at least 6 turns. This presents a safety issue when going O/R or when going over bumps as it might rip a rim/tire off the truck. Advised me to find longer lugs or to get new rims with 7 or 8" width. They tried to find longer lugs but their supplier doesn't carry longer one's. Said the narrower rim would also help with issue #1.
So they put everything back the way it was when I dropped it off. Luckily, I wasn't charged for the work. Wanted to get your opinions/advise before I went out and bought new rims and cause the next set of problems. I'd prefer to go with longer lugs as this sounds like a less expensive solution. Does anyone make longer lugs for the tacos? What size are the stock lugs? Or Are 7 or 8" rims the answer?
For now, I'm going to mount the stock rims/tires and run those until I decide which path to take. Thanks.
XD
TRDXD45 is offline   Reply With Quote
Old 11-19-2007, 08:14 PM   #2 (permalink)
View kyle@tirerack's Photo Gallery
The BFG 265 70 17 is recommended for a wheel width of 7-8.5 inches so may be a little narrow for the wheel you have. It's also true that you need at least 6.5 turns on the threads for your lugs. You might try for longer studs but they might be difficult to find. Feel free to send a message if you want to discuss the details.
kyle@tirerack is offline   Reply With Quote
Old 01-04-2008, 01:45 PM   #3 (permalink)
View markrhody's Photo Gallery
Nitto Terra Grappler
Nitto has Terra Grapplers that are a P265 /70/r17 size, acceptable for use on up to 9" rims
markrhody is offline   Reply With Quote
Old 01-09-2008, 10:46 PM   #4 (permalink)
View nowherain's Photo Gallery
bad bearings
does anyone know the rear wheel bearing no. for the corolla NZE121 , or even a downloadable manual ( free) i have got some bad bearings , and the mech wants me to change my entire wheel hub instead
nowherain is offline   Reply With Quote
Taco tailgate...POS arctic_front 2nd Generation (2005+) 102 05-14-2010 07:26 PM
2002 Camry soft brake issue Ken4 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-08-2007 07:39 AM
Taco vs. Tundra ShadowForce 1st Generation (2000–2006) 15 05-01-2005 07:05 AM
Speedo off in an 05 Taco? goldmember 2nd Generation (2005+) 13 04-27-2005 04:41 PM
Newbie. & Lucker. 05 Toy Taco questions. Oiler 2nd Generation (2005+) 6 03-25-2005 08:47 AM
