20" Tundra's Wheel on 01 Land Cruiser???? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 12-12-2007, 04:41 PM   #1 (permalink)
View mkivowner's Photo Gallery
Need help Please....Do you think will it fit??? Thanks....
Regards,
mkivowner is offline   Reply With Quote
Old 12-14-2007, 12:35 PM   #2 (permalink)
Rocket!
TRAVISDTD's Avatar
View TRAVISDTD's Photo Gallery
what year Tundra?
TRAVISDTD is offline   Reply With Quote
Old 12-14-2007, 01:34 PM   #3 (permalink)
Originally Posted by TRAVISDTD View Post
what year Tundra?
Stock 20" 2007 Tundra Wheels.
Thanks,
Old 12-14-2007, 01:58 PM   #4 (permalink)
Rocket!
TRAVISDTD's Avatar
Should work great make sure you use an OE lug that is built for the wheels.
20" 2007 Tundra wheels 20x8 60 offset 110.20mm hub
16" 01 Landcrusier 18x8 60mm offset 110.00mm hub.
*I would check for break clearance just to make sure before you drive with them. the x factor of the tundra wheels might be different but You are probably ok.
Old 12-14-2007, 05:16 PM   #5 (permalink)
Great! Thank You much
Is it ok if .20mm hub different?
Regards,
Old 12-14-2007, 05:18 PM   #6 (permalink)
Rocket!
TRAVISDTD's Avatar
yeah no sweat. when you bolt them down do it by hand in the star pattern then torque them by hand too. Don't use an air gun, that should help you center them if there is a little play.
Old 12-15-2007, 06:34 AM   #7 (permalink)
Cool! Thanks again bud.
Regards,
01 Avalon Wheel Offset? trashorspam 2nd Generation (2000-2004) 1 11-24-2005 09:09 PM
Tilt Wheel Vs Non-tilt Wheel atd332 Archived Corolla threads 0 07-15-2005 10:17 PM
No horn / steering wheel basic electrical stilllearning6 Celica Forum 1 03-17-2005 07:38 AM
BAd Experience Beware: GreenBay Tires 86B Feedback: Buyers, Sellers, and Vendors 4 06-08-2004 04:10 PM
