Stock Aluminum wheel with 285/75/16 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 01-11-2008, 12:50 AM   #1 (permalink)
View SilverTacoma's Photo Gallery
USA Stock Aluminum wheel with 285/75/16
I am looking at replacing the tires on my 05' stock Tacoma.
I am currently running the stock 245/75/16 tire. Will the 285/75/16 have any problems mounting on a stock aluminum rim? The reason I ask is that I am not sure if the width of the stock rim is wide enough for the newer tires?
Would I require a lift kit?
Thanks!
TC
SilverTacoma is offline   Reply With Quote
Old 01-11-2008, 07:50 AM   #2 (permalink)
View kyle@tirerack's Photo Gallery
I believe the width is 7" on the stock wheel and normally the 285 is recommended on range of 7.5-9. In regards to clearance you'll add about 2.3" in overall diam. from the current tire which would be split above and below the axle. I'm unsure if it will clear without issues ....may have to do some measuring to see. Let me know if I can help.
kyle@tirerack is offline   Reply With Quote
Old 01-23-2009, 11:05 AM   #3 (permalink)
View paintgirl's Photo Gallery
will these fit?
Sounds like you guys have the scoop. I need help too.
I have a 98' 4runner with 31x10.50 15r LT tires and stock alum rims. wanting to know if I can put 2007 tacoma tires/rims on it? they are 245/75/16.Will they fit?
paintgirl is offline   Reply With Quote
Hubcentric versus Lugcentric Panama Red 2nd Generation (2005+) 102 09-12-2007 04:03 PM
Replacing the Stock steering wheel with something a lil' better ScrooYoo 5th & 6th Generation (2002-2006 & 2007-2011) 8 04-04-2007 01:09 AM
Adding stock steering wheel controls Quin 2nd Generation (2005+) 6 04-10-2006 01:24 PM
wheel size for a gen2 other than stock? xrs22 1st & 2nd Generation (1983–1986 & 1987-1991) 3 03-08-2005 12:30 PM
05 Xrs Stock Wheel offset? djwolford Archived Corolla threads 0 02-11-2005 02:03 PM
