suggestions for these wheels - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 01-27-2008, 11:21 PM   #1 (permalink)
View xlegendx's Photo Gallery
4th Generation suggestions for these wheels
i just bought some 17x7.5 with the bolt pattern of 5X114.3 and the offset is +45 wheels for my 97 camry le. does anyone know the offset of my car and what are the specifications of the tires do you guys suggest i buy? thanks^__^
xlegendx is offline   Reply With Quote
Old 01-28-2008, 09:00 AM   #2 (permalink)
View kyle@tirerack's Photo Gallery
I believe the factory offset was roughly 40. You could use a 215 45 17. You can search by size at link...let me know if I can help. Tires
kyle@tirerack is offline   Reply With Quote
Old 01-28-2008, 01:37 PM   #3 (permalink)
thanks. i read in some sites that my offset is like 35-42... and i'm scared that these wheels have 45 offset so that's why i was wondering.
Old 01-30-2008, 08:41 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
If it rubs, just get some spacers. You probably will only need a few mm in the rear if any at all.
I had 215/50-17 tires on a 17x7 +40mm wheel on my 2000 Camry and there was 5mm or less clearance between the rear tire and strut. I know it rubbed occasionally though since there were some clean spots on the otherwise dirty strut.
2007 Camry 2.4L 5M
Old 02-05-2008, 05:38 PM   #5 (permalink)
Rocket!
TRAVISDTD's Avatar
View TRAVISDTD's Photo Gallery
45mm is the limit. Look at the Falken 452 in the 215.45.17. They tend to run a little narrower which will help to keep you clear. You could also consider a 205.50.17. Yokohama YK520's are awesome tires.
TRAVISDTD is offline   Reply With Quote
