bolt size or lug nut problem?
Hi there,
I m new to this site, hope you guys can help me out here
I was thinking of getting a set of used winter tires with alloy wheel off my friend's 2004 mazda RX8 (RWD) for my 2007 Toyota Camry Hybrid (FWD).
I was able to put the wheel on but I wasnt able to put the Toyota OEM lug nut on the stud of the aftermarket rim that came off from the RX8. My question is that do i simple buy a new set of lug nuts that fit the studs or there are other implications?
Second question, 2004 RX8 has 5X114.3 same as my camry, but I dont know if the offset of the aftermarket rim fits my car which has 45+ i think.
my stock tire size is 215/60/16, the aftermarket set is 215/55/17, it should be ok right?
THanks so much for your help/advice!!
