97 Camry Rear Aligment Problem?
97 Camry LE. with 70k miles
I just noticed that I have irregular wear on my rear tires. The driver rear tire is feathered (it worn more on the outside, 3:1 ratio) . The passenger rear tire has the same feather effect, but it less pronounced.
Front Tires appear to wear evenly across.
Now the question I have is I heard that Camry has independent rear suspension.
Are the Camber, caster or Toe in are adjustable. I am assuming that my wheel alignment is way off causing the uneven wear.
1. What type of wheel alignment it need? (regular wheel alignment or 4 wheel alignment)
2. After the alignment is done, can I just use the tire in it original location?
3. There is still life in the tire can I left it in the same location, will this throw off the alignment again in the future?
