Accord Wheels On Solara - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 12-01-2008, 08:43 AM   #1 (permalink)
toyota200x's Avatar
View toyota200x's Photo Gallery
I am wondering if a set of 2003 Accord Wheels (4cyl EX) will fit my 2001 Solara SE 4cyl. It seems like the bolt pattern is correct but I don't know about the center bore and other factors. Any help is appreciated.
toyota200x is offline   Reply With Quote
Old 12-02-2008, 10:27 AM   #2 (permalink)
Wheel & Tire Guys
Discount Tire's Avatar
View Discount Tire's Photo Gallery
The offset on the Accord wheels are too high for the Solara, so they will not work with out modifications. The center bore and bolt pattern are good though.
Low Prices! More Choices! FREE Shipping!
www.discounttiredirect.com
1.888.459.4080
Found a Lower Delivered Price?
Stock to Rock - Discount Tire's FJ Build Thread!
Discount Tire is offline   Reply With Quote
Old 12-03-2008, 08:50 AM   #3 (permalink)
toyota200x's Avatar
What are the offsets on the Solara 4cyl SE and the 2003 Accord? I thought they were both pretty close. Thanks so much for your help.
What modifications would need to be done to make them work?
Old 12-03-2008, 10:11 AM   #4 (permalink)
toyota200x's Avatar
Would a set of 2002 Acura TL 17" wheels work any better on my Solara? Tires size 235/45zr17
Old 12-03-2008, 12:28 PM   #5 (permalink)
Wheel & Tire Guys
2003 Accord SE wheels are 16x6.5 with a 55mm offset
Your Solara has an offset range recommendation of 35-40 for a 6.5" wide wheel.
Here are the recommended offset ranges for your solara
Wheel width * Offset ranges
6.0 ------------ +35/+45
6.5 ------------ +35/+40
7.0 ------------ +35/+40
7.5 ------------ +35/+45
8.0 ------------ +38/+40
These are 17x7 with a 55 Offset. These also, may be too high of an offset. The tire size would be great though.
You'd have to test fit them to see what you would need to do. higher offsets make the wheels tuck more and the more a wheel tucks the closer it comes to interfering with brake and suspension components.
Hope this helps some.
-Travis
If you are looking for an inexpensive alternative. Maybe you should consider this...
Get 30% Off Your Discount Tire Direct Purchase
We can put you into a wheel and tire package that we will guarantee will fit and will be brand new.
1.888.459.4080
