Can a wheel locking nut throw off balance? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 02-23-2009, 08:34 PM   #1 (permalink)
luck123's Avatar
View luck123's Photo Gallery
Need some advice from folks that have experience balancing wheels.
I have some tuner nuts for some after mkt alloy wheels I will be using for winter. Because the wheel has a centre cap covering the nuts, I purchased spline drive open ended lug nuts.
I did find some spline drive closed ended locking nuts that would fit, but they are slightly bigger and heavier than the regular lugs.
Could the locking nut throw off the balance of the wheel?
One tire shop said it shouldn't be a problem, but install the locking nut opposite the valve. Not sure about the logic of this stmt if the wheel is already perfectly balanced prior to install with lug nuts.
Thx.
09 Black HL Sport, loaded Cdn version: AWD, bk leather int.
Mods: tinted windows; upgraded headlight and fog bulbs; bug deflector
; Ichiba 15mm bolt on wheel spacers, Pioneer FH-P8000BT head unit; Blaupunkt underseat sub, Viper 5901 security/auto start, stainless dual exhaust tip, upgraded horns.
luck123 is offline   Reply With Quote
Old 02-24-2009, 10:11 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The nuts are placed so close to the center of the rotating system (hub, wheel, tire,brake disc/drum etc.) that the center of mass is not affected. That is why wheel weights are clipped to the farthest possible location.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is online now   Reply With Quote
