245 with spacers? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 12-06-2009, 07:08 PM   #1 (permalink)
Camry Expert/MR2 JR Xpert
jtex2717's Avatar
Gameroom cash: $272115
View jtex2717's Photo Gallery
3rd Generation 245 with spacers?
Hey DT.
I have a 96 Camry 4cyl Coupe
I bought 4 G35 Sedan Wheels for $200 the specs for the wheels and tires are 225/55/17 5x114.3 66.06 hub bore 45mm offset 17x7
Edit: The current tires are 225/55/17
I put them on and they were rubbing the struts like crazy......Do you think with a 20mm hub spacer and 60.1 to 66.06 hub ring, will fit how I need them to fit w/o any problems?
Edit: I plan on running 225/40/17 for tire height
Also would I have to roll my fenders? Would there be a problem with a 2inch drop?
Thanks
Finally Red MKII MR2 5s & Metallic Blue 96 Cam 1MZ
Watch out for the build thread!!!
IM BAAAAAACK!!!!!!!
jtex2717 is offline   Reply With Quote
Old 12-07-2009, 01:18 PM   #2 (permalink)
Wheel & Tire Guys
Discount Tire's Avatar
View Discount Tire's Photo Gallery
Originally Posted by jtex2717 View Post
Hey DT.
Thanks
Thank you for the post.
We do not recommend the use of spacers. If a wheel does not fit without the use of spacers/adaptors, it shouldn't be on the vehicle. However, according to my information the +45mm offset is the highest recommended offset on your 96 Camry for a 7" wide wheel. That said, if you switch to tire size 215/45-17, you should not have any tire rub even with the 2" drop.
As far as the hub rings go, I am unaware of any manufacturer's who produce hub rings in size 66.1 to 60.1. The closest available is size 67 to 60.1. To be exact, you'll need to have a set custom made.
I hope this information helps. If we can be of further assistance please let us know.
-Matt
Low Prices! More Choices! FREE Shipping!
www.discounttiredirect.com
1.888.459.4080
Found a Lower Delivered Price?
Stock to Rock - Discount Tire's FJ Build Thread!
Discount Tire is offline   Reply With Quote
Old 12-07-2009, 07:00 PM   #3 (permalink)
jtex2717's Avatar
Now i just found out that the wheel might be 17x7.5 will that make a difference?
IM BAAAAAACK!!!!!!!
Old 12-07-2009, 07:27 PM   #4 (permalink)
93 Camry LE 5S-FE
4Cyl'erThriller's Avatar
Gameroom cash: $428696
iTrader Score: 15 reviews
View 4Cyl'erThriller's Photo Gallery
3rd Generation
It might. I went from a 225/45/17 tire to a 215/45/17. It looked like the fenders would have had to been rolled with the larger tires, so that extra .5 inch may make a differance when it gets dropped.
4Cyl'erThriller is offline   Reply With Quote
Old 12-07-2009, 08:07 PM   #5 (permalink)
jtex2717's Avatar
So how would I compensate for the extra .5?
IM BAAAAAACK!!!!!!!
Old 12-07-2009, 10:04 PM   #6 (permalink)
93 Camry LE 5S-FE
Rolling the fenders may work. Not sure. Im sure if you search you can find someone who has the same rim mod on here.
Old 12-08-2009, 09:10 AM   #7 (permalink)
Wheel & Tire Guys
That should work as well according to my information. With the 215/45-17's mounted on a 7.5" wide wheel +45mm offset, the package will only stick out about 1/2" (.4") further out from where the OE assembly sits.
1.888.459.4080
