DIY: Refinishing Steel Rims (Video) - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 07-29-2011, 04:41 PM   #1 (permalink)
View ProStreetDriver's Photo Gallery
Exclamation DIY: Refinishing Steel Rims (Video)
How to refinish steelies on a budget. This involves repainting your rims using spray bomb/rattle cans.
What you'll need:
flat screw driver, paint marker, wire brush, 200-400 grit sandpaper, brake cleaner, clean cloth, painter's tape, paper, dull knife/flat edge, primer, paint (color choice)
Procedure:
-remove rims from vehicle
-mark where wheel weight are located with paint marker
-remove loose rust and paint using wire brush
-sand down rim using 200-400 grit sand paper
-clean rim using brake cleaner and cloth, then let dry off in sun
-tape off tire and valve stem
-primer rim and allow for approximately 10min dry time
-apply selected paint choice (3 coats)
-let paint dry and remove tape
-reinstall wheel weight
-reinstall rim on vehicle
ProStreetDriver is offline   Reply With Quote
