2010 Camry wheels fit on 2007 Sienna? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 08-24-2011, 01:28 PM   #1 (permalink)
View Johnnyph's Photo Gallery
I found a used set of winter tires + steel wheels from a 2010 Camry. The size is 215/60/R16. My 2007 Sienna wheels and tires size is 215/65/R16.
So the Camry overall tire size is a little smaller, which I don't mind.
Would the steel rim have the same bolt pattern and size? also inner clearance not touch the brakes?
Also, would the Camry tires be strong enough to support Sienna? (The reason I worry about this is because my SUV has to use SUV tires with stronger sidewall than regular sedan tires to support the weight. Not sure if the same thing applies to a minivan Sienna which is heavier than Camry.)
ps. I already posted this in Sienna forum, but this forum might have better responses.
Johnnyph is offline   Reply With Quote
