Re: Re, Brakes
On Thu, 12 Jan 2006 23:08:50 -0600, "Ray O"
<rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
>"Gord Beaman" <gord@islandtelecom.com> wrote in message
>news:jh3es1psht9d0qr2c7up05dsju7qs72gsm@4ax.com...[color=green]
>> "Ray O" <rokigawa@tristarassociatesDOTcomn> wrote:
>>[color=darkred]
>>>"Digit" <ddpowell@paulbunyan.net> wrote in message
>>>news:e358b2af60e17fa2a653201e13f9a871@localhost.talkaboutautos.com...
>>>> Need to know what tools, other then basic hand tools ,that are needed to
>>>> replace pads and rotors on a 2003 corolla.
>>>Yes, you would need to know what tools, other than basic hand tools, are
>>>needed to replace pads and rotors on a 2003 Corolla so you can assemble
>>>the
>>>tools prior to attempting the work.
>>>You will need:
>>>A jack
>>>Jack stands
>>>A wheel chock
>>>A can of brake cleaner
>>>Set of metric wrenches inclcuding 12 through 16 mm and whatever size is
>>>needed to remove the wheel lug nuts
>>>Wire brush (toothbrush size is good) to clean up the clips and springs
>>>Flat bladed pry bar or screwdriver to get the caliper off
>>>Safety glasses
>>>High temperature wheel bearing grease or anti-seize to use on the slides
>>>and
>>>hub-rotor-wheel interface
>>>Rags or paper towels
>>>A couple of quarts of brake fluid if you want to flush it while you're at
>>>it
>>>(add a 10 mm box wrench and container to catch the flushed brake fluid to
>>>the list of tools)
>>>The list of "nice to have" tools would include an air compressor, impact
>>>wrench and impaqct sockets,. air ratchet, vehicle lift, and parts washer.[/color]
>> If it were me I'd add a knowledgeable blonde tech with long legs
>> so I could watch her work as I quaffed a cool one and gave
>> advice...(but then, that's just me)...YMMV... :)
>> -Gord.
>> (use gordon in email)[/color]
>I'd heard of a female brunette Hyundai tech who supposedly worked as an
>"exotic dancer" and could probably handle the brake job without any
>problems...[/color]
She could handle my 'brake' job....
Scott in Florida
