Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 89 leaking oil from speedo cable
View Single Post
Old 01-20-2006, 03:47 PM   #3 (permalink)
toyotaspeed90
Gameroom cash: $133755
the seal at the tranny end is bad (you will probably need to remove the speedo drive gear and replace the oring). and that is gear oil coming through the cable... it does happen...
since i wrote that before i read the whole post.... you might want to try and get a new oring from toyota (of if thats what you did try getting a slightly larger oring) and also cleaning up the edges where the speedo drive gear sits in the tranny.
Which cable did you replace? the ae92's use a 2 piece cable... an upper and a lower.... the lower one being only about 12" long and attaches to the tranny directly.
toyotaspeed90 is online now   Reply With Quote
