Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - keyless entry for a 2005 tacoma dbl cab
View Single Post
Old 01-26-2006, 03:00 PM   #13 (permalink)
fredlyzone
View fredlyzone's Photo Gallery
Thumbs up
Originally Posted by BowtieGuy
The vehicle should meet the following conditions before proceeding; *The key is NOT in the ignition *Driver’s door is OPEN (The others are CLOSED) *Drivers door UNLOCKED (Not necessary for Echo) 1) INSERT and REMOVE the key from the ignition cylinder, TWICE within 5 seconds 2) CLOSE and OPEN the driver’s door TWICE within 40 seconds 3) INSERT and REMOVE the key into the ignition cylinder 4) CLOSE and OPEN the driver’s door TWICE within 40 seconds 5) INSERT the key in the ignition and CLOSE the driver’s door 6) Turn the ignition switch from LOCK to ON and back to LOCK at approx. 1 sec. Intervals “ 2” times to enter REWRITE MODE 7) REMOVE the key from the ignition (The door locks are cycled LOCK-UNLOCK within 3 seconds TWICE to let you know that you have selected REWRITE MODE) 8) Within 40 seconds press BOTH the LOCK & UNLOCK buttons on the transmitter simultaneously for 1 second (Press and release). 9) Within 3 seconds press and release the LOCK button on the same transmitter (The door locks will cycle ONCE if the transmitter was recognized and TWICE if it was not recognized {if you get two cycles start over}). 10) Within 40 seconds repeat step 8 and 9 with any other transmitters you wish to program 11) One of the following will END the Rewrite mode; *40 seconds elapses *Drivers door is opened *Key inserted into the ignition cylinder *4 transmitters are registered
Dude,
You are the man!!!
Thanks a lot for the instructions. They work like a charm.
Fred
fredlyzone is offline   Reply With Quote
