remote starter/security system - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2002, 09:31 PM   #1 (permalink)
View wontonjohnny's Photo Gallery
has anyone installed there own system???
are the instructions good enought for anyone to DIY???
5 speed 3vzfe - RIP
project F23 CL-T
Custom Y-pipe Project
Custom 1-Piece CAI Project
wontonjohnny is offline   Reply With Quote
Old 10-25-2002, 01:59 AM   #2 (permalink)
Luc
View Luc's Photo Gallery
I've installed a few before and it's relatively easy, once you have the wiring diagram. Most Toyotas use negative (ground) triggers, and if you have a good understanding of them, as well as relays, then it's not hard. However, I've never installed a remote start on a manual transmission vehicle, you have to be very careful as the neutral safety switch will need to be bypassed. There aren't too many remote start modules out there that will allow wiring up a manual transmission, so check around.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 10-26-2002, 12:40 AM   #3 (permalink)
yeah im looking into getting the new compustar. are those more complicated to install?
are there any special tools ill need like a voltmeter?
5 speed 3vzfe - RIP
project F23 CL-T
Old 10-26-2002, 02:01 AM   #4 (permalink)
Luc
I've never looked into Compustar, so I can't answer that for you. :-? A voltmeter is always useful to have working around the car's electrical system. But for alarms, it isn't really needed, just wire stripper, crimper, t-taps, etc. and some patience to clean up all the extra wires after everything is installed. Last time, I had to clean up such a bad install on a friend's Prelude, which had wires dangling right above her feet and half the features weren't even hooked up!!!
Luc
