Will new speakers help my "Premium" stereo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2002, 04:33 PM   #1 (permalink)
View Evad's Photo Gallery
Hi all!
I have a 2002 Highlander Limited and supposedly it has a nice stereo.
Its weak at best.
Before I spend a boatload on a new stereo, I thought I would change out the 4 speakers with better ones.
1) Anyone know the wattage output of my stereo?
2) What brand of speakers do you reccomend? These will replace the existing 5" or 6" round speakers, and at this time I dont really want them cutting door panels.
Any help is appreciated!
Evad
2002 Toyota Highlander Limited
Evad is offline   Reply With Quote
Old 10-30-2002, 11:02 AM   #2 (permalink)
View FargoToyota's Photo Gallery
Premium???
Highlander Limited or Highlander?
JBL 3-in-1, JBL 6-disc 3-in-1, or Toyota 3-in-1?
I'll find out if you get me these answers. =)
FargoToyota is offline   Reply With Quote
Old 10-30-2002, 12:09 PM   #3 (permalink)
Hey thanks for responding!
I have a limited, and the best stereo option they have which is 6-disc 3-in-1
Any thoughts are appreciated
Evad
Old 10-30-2002, 02:14 PM   #4 (permalink)
View PLRBEAR's Photo Gallery
Which means your speakers probably work off a Toyota specific JBL amplifier. You'll basically have to bypass the JBL amp, and even then, i don't think the factory headunit will work without the JBL amp.
'99 Camry 5S-FE
PLRBEAR is offline   Reply With Quote
Old 10-30-2002, 03:01 PM   #5 (permalink)
Luc
View Luc's Photo Gallery
You'll be surprised to find that the premium systems in the Toyotas use speakers that are rated about 3-ohms, catered to the amp, whether it's Toyota or JBL. If you get aftermarket speakers, get ones with higher senstivity ratings (in dB). You will be able to use the OEM amp to run the speakers. The OEM amp is probably something like 15-20 watts of continuous power.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 10-30-2002, 03:45 PM   #6 (permalink)
That is what I was afraid of. If its not as easy as simply replacing the speakers, then I will likely replace the whole thing.
Thanks guys.
Evad
Old 10-30-2002, 06:19 PM   #7 (permalink)
Finally, I tracked it down.
After looking through my 2001, 2002, and 2003 source books, the owners manual, and four different 1-800 Toyota numbers, I've finally found out the wattage for the JBL systems in the Highlander.
Survey says: 200 Watts.
Enjoy!
Old 10-31-2002, 01:38 AM   #8 (permalink)
Luc
200 watts of maximum power with 10% distortion isn't real power at all, it's a selling point.
Luc
Old 11-02-2002, 12:02 AM   #9 (permalink)
Yes I agree. There is no way these speakers have a prayer of handling that much power.
Evad
