how to make an inverter switched w/ ignition - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2005, 10:13 PM   #1 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
well, i took your other advice and installed my inverter like an amp,
with a deticated power line to the battery with a fuse and all
but its kinda annoying to have to turn it on and off all the time whenever i want to use the DVD player since its undernieth my seat.
is there anyway to have it turn on and off with my ignition?
thanks guys
alex
alex is offline   Reply With Quote
Old 10-12-2005, 10:20 PM   #2 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
if it has a toggle switch then you should be able to remove that in light of a acc line. Not sure, that would work if it were a +trigger.
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 10-12-2005, 10:22 PM   #3 (permalink)
DJModifyd
alex's Avatar
yea it has a toggle switch...exactly what do you mean remove that in light of the acc line?
Old 10-12-2005, 10:33 PM   #4 (permalink)
How Ya Like Me Now?
Heres what i would do. Id ask some like 88le also.
Dissconect one part of the switch, mabye the line that goes from the on to the board, splice that into a relay. Wire the relay so that it only comes on with a ACC line (like the headunit) and wire it back to the board. follow?
98 V6 XLE
Old 10-13-2005, 07:42 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Rewiring the switch through a relay would work. But you have to find out what voltage the switch is working at.
Then get a relay that'll work at that voltage.
"Skoolin' the unlearned!"
Old 10-13-2005, 08:52 AM   #6 (permalink)
DJModifyd
alex's Avatar
ok....i'll just be lazy and hit the damn switch!
thanks guys!
