Final Going Active Questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2005, 09:45 PM   #1 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
I'm making this thread for my final going active questions.
1. I've heard alot that tweeters are 8 ohms. I cant find much information regarding my own tweeters. Does it matter what ohm they are?
2. Am I Going to need a relay to run 4 components on one turn on line.
3. Do I play around with the gains aswell? To adjust the stregnth balance?
4. The Low pass filter for my sub should be around 250. unfortunalty i dont have a resistor for this, so what im planning on doing is running it at 2600 in the xover and then running the sub on the LPF to its current settings? Is this ok?
There will be more to come.
Thanks
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 10-26-2005, 11:31 PM   #2 (permalink)
cam2Xrunner's Avatar
No doesn't matter.
I don't think so, just run two turn on lines from the back of the CD player, that's what I'm going to do anyways.
Start with the gains at minimum, and also turn the volume all the way down before you set the crossover points.
The low pas filter for your sub should be between 63-80hz. 100 hz tops. Do you have a sub crossover on the headunit if you don't have that crossover point in the Audiocontrol?
Thanks
Basic Settings
Tweeter HPF 3KHZ
Mid HPF63hz or 80 hz
Mid LPF 2.15khz to 3khz
Sub LPF 63-80hz
Old 10-26-2005, 11:37 PM   #3 (permalink)
How Ya Like Me Now?
Cheers
I have to have the car off and stuff to set the xover points. Not sure what you mean my have the volume all the way down to do it. cause its a hardware piece
i dont have one in the headunit. will my ghetto rig work until i can get the correct settings. but i may have something that low
infact i do. my subs stats are up too 250 whch i will take as wrong, should i start high or low?
98 V6 XLE
Old 10-26-2005, 11:41 PM   #4 (permalink)
bigloubumpin's Avatar
Gameroom cash: $151645
View bigloubumpin's Photo Gallery
Good luck, I just finished my setup yesterday afternoon,it was no picnic.
bigloubumpin is offline   Reply With Quote
Old 10-26-2005, 11:45 PM   #5 (permalink)
How Ya Like Me Now?
ugh, any tips or anythign?
98 V6 XLE
Old 10-26-2005, 11:59 PM   #6 (permalink)
Cheers
250 is way too high, 100hz tops imo.
I'm going to cross mine over at around 63 hz.
Old 10-27-2005, 12:00 AM   #7 (permalink)
Notice any difference for the better? And why not use the ID mids?
Old 10-27-2005, 12:00 AM   #8 (permalink)
How Ya Like Me Now?
k
ill start at my highest which i think is like 90
98 V6 XLE
Old 10-27-2005, 12:20 AM   #9 (permalink)
I was uninstalling the mids the other day when I drove a screw thru the surround & dustcap--ouch,so I decided to try these inexpensive drivers.
Old 10-27-2005, 12:21 AM   #10 (permalink)
cam pretty much covered all the bases in his reply
Old 10-27-2005, 07:52 PM   #11 (permalink)
How Ya Like Me Now?
I recall earlier rob reccomending that i use the mtx for th tweets. is there a reason for this or anything?
98 V6 XLE
Old 10-28-2005, 11:10 PM   #12 (permalink)
How Ya Like Me Now?
rob? anyone?
i just finished running the 2nd pair of wires into the doors. god i hate doing that, but im done forever. or at least till the next whip
98 V6 XLE
Old 10-28-2005, 11:20 PM   #13 (permalink)
rob? anyone?
I feel ur pain,probably the hardest thing I had to do during my install,getting that 16awg thru that little rubber boot was no picnic.
Old 10-29-2005, 01:11 AM   #14 (permalink)
Don't matter now that you have a capable crossover.
Try them both out and see which one you think makes the overall system sound better.
They both rated for the same power right?
If not, use the stronger one on the mids.
Old 10-29-2005, 01:13 AM   #15 (permalink)
How Ya Like Me Now?
they are both rated for the same, or the mtx is like 5 more rms. The Monitor is the better one, so ill try it out on the tweets before, cause it has no turn on pop, which ive heard can damage them
98 V6 XLE
