speakers white noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2005, 02:02 AM   #1 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
am i hearing slight hissing from my rear speakers cause my HU has a low voltage preout?
its 2.5V
would it go aways if i got a HU that put out something like 4V?
WhiteRabbit is offline   Reply With Quote
Old 11-04-2005, 02:29 AM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
are you using amplifers? if not, than it doesnt have anything to do with voltage.
most likely in either case, youve got some bad connection somewhere between the speaker and the source. track it down and youll be golden.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 11-04-2005, 02:49 AM   #3 (permalink)
TN's furry friend
yea, theyre running off an amp
Old 11-04-2005, 03:44 AM   #4 (permalink)
cam2Xrunner's Avatar
Try turning the gain down a little bit. At what volume did you set your gains? And I assume the RCA's are wired on the oppsite side of the car as the power wire, or at least far away. Does the RCA cross over the power line at anypoint?
You might also want to check your grounds.
Old 11-04-2005, 08:39 AM   #5 (permalink)
View ccfoo242's Photo Gallery
Even with the gain down, some amps will produce some hiss. Even with a high S/N ratio you can hear hiss. Turn on your home stereo and turn the volume down, stick your ear up to the tweeters...you'll probably hear it.... But it shouldn't be loud, like a cassette without dolby NR...LOL...
ccfoo242 is offline   Reply With Quote
Old 11-04-2005, 09:28 AM   #6 (permalink)
TN's furry friend
yea the gains are pretty low and the RCAs run on the opposite side of the car from the power cables. the rcas cross with the power cable at the amp. but its 90 degrees.
Old 11-04-2005, 09:24 PM   #7 (permalink)
TN's furry friend
you only hear the hiss when the volume is turned low, when its up, it gets drowned out i guess.
Old 11-04-2005, 10:20 PM   #8 (permalink)
Here is a similar problem posted by someone in a home audio forum:
http://archive.avsforum.com/avs-vb/h.../483916-1.html
The hiss from my amp, with no inputs and gain turned down, was annoying because I had tweeters pointing right at my head. I redirected the tweeters and it was less. Eventually I stopped noticing it. Everyone thought I was crazy anyway, I was the only one who noticed.
Old 11-04-2005, 10:27 PM   #9 (permalink)
TN's furry friend
so howd he fix it?
Old 11-06-2005, 11:05 AM   #10 (permalink)
Originally Posted by WhiteRabbit
so howd he fix it?
I don't think there is a fix, other than getting a new amp. Just how loud is the hiss?
Old 11-06-2005, 01:24 PM   #11 (permalink)
Tommy's Avatar
The hiss could just be the sign of a poorly constructed amplifer, and if thats the case, well....buy a new amp, lol
My garage
Old 11-06-2005, 05:57 PM   #12 (permalink)
TN's furry friend
k i figured it out. i had the PreEq switch turned on without knowing, DOH!
thanks for everyone's input.
