new subs and amp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2005, 02:52 PM   #1 (permalink)
View Bruce Campbell's Photo Gallery
new subs and amp
im looking into buying ed NINe.2X amp and and 2 ed 12" Ov.2 subs to compliment my system i have now. I lsiten to all types of music so i wand the deep loud bass for rap and hard hitting bass for rock, right now i have 2 6.5" alpine s-type in the door and 2 6x9 s-type in the rear deck all four hooked up to a 40 watt rms amp. Do these subs sound like a good idea or should i go with one 12 or 2 10"s. From what ive heard from subs i didnt like 10"s that much just becuase i didnt feel like they really got down to the low frequencies as well as 12"s do but would 2 12"s be over doing it. What do you think
Bruce Campbell is offline   Reply With Quote
Old 11-06-2005, 03:16 PM   #2 (permalink)
cam2Xrunner's Avatar
Those are awesome subs, and the nine2X is a very strong class AB amp. I'd go with the 2 12's myself, in a sealed enclosure.
For an alternative amp choice, check out the MB Quart RA2400 @ Crutchfield. Does 800 watts rms x 1 @ 4 ohms. 249 shipped.
Old 11-06-2005, 04:11 PM   #3 (permalink)
for those subs should i get the 2ohm dvc or 4 ohm dvc and how should i wire it
Old 11-06-2005, 05:34 PM   #4 (permalink)
For two subs so that your amp will see a final 4 ohm load, you will want to use two dual 4 ohm DVC subs. Then wire them like the picture above shows. (you can also use two single Voice Coil 8 ohm subs, but those aren't too common anymore)
Here's a link to play with different ohm variations to see what works.
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Old 11-06-2005, 11:42 PM   #5 (permalink)
thanks for that, now how about sound deadening of the trunk, my 6x9's are open to the trunk is the sp levels of the subs going to hurt the sound quality of my 6x9's should i put that deadening paper around my trunk or anything you recomend me doing
Old 11-07-2005, 01:10 AM   #6 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
yea most def
look into getting a rool of raamatt
do the trunk lid and the rear deck at least
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 11-07-2005, 01:33 AM   #7 (permalink)
ok so do i just cut one peice for the deck and completly cover over the rear speakers like stick it to the bottum of the magnets on the 6x9's so when you look up at the rear deck all you see is the sheet, and likewise with the lid just cover the entire thing with one piece
Old 11-07-2005, 01:40 AM   #8 (permalink)
Take out the rear 6x9's. You won't need them after you have a nicely setup front component system. Also by having those speakers back there the subs are going to cause them to distort and sound even more crappier. Also when you take out those rear speakers you are allowing more bass to get into the cabin.
For deadening the rear deck you will want to use a bunch of pieces of mat, not just one big sheet. That will cause wrinkles and you won't really be doing a good job of effectively deadening. Instead use 2-3 layers of smaller peices.
The way I would deaden the rear deck is about 2 layers on the top of the deck, then one lyer on the bottom. Then use some foam inbetween the deck and the deck panel. This will halp diffuse any rattles between the rear deck and the deckpanel.
www.sounddeadenershowdown.com See which deadener is best for your budget.
I chose and reccomend www.raamaudio.com He also has Ensolite foam which is good stuff for between the deck, and the decklid.
Old 11-07-2005, 02:15 AM   #9 (permalink)
well im not looking to buy a component system soon and im planning on leaving the 6x9's in there is there a way i could seal them off so that the subs dont distort them
Old 11-07-2005, 10:00 AM   #10 (permalink)
I think Crutchfield might sell baffles that you can mount underneath them.
