Would it be possible to mount the sub right behind the rear seats, facing forward, with a removable mesh grill right behind it and use your entire trunk as an enclosure? I know it's a big space, but I suppose if you set it up right you would get a nice, low tone, save a lot of space, and the mesh would prevent anything in your trunk from rocketing forward and smashing your sub. Yay, nay?
Philly
http://freewebs.com/popeface
1997 Camry LE I4
Originally Posted by theamazingnate
a good mechanic is like a good bj giver- you always go the person that gave the service to you, and if they are not available - you just sit at home and fiddle with the problem yourself until a substandard result is met
