what wattage amp kit should i buy.plus amp for woofer or speakers?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2005, 10:15 PM   #1 (permalink)
View TheGhostCamry's Photo Gallery
3rd Generation what wattage amp kit should i buy.plus amp for woofer or speakers??
OK,i have a question for all of you hardcore audio experts .i have aftermarket 6x9's in the rear of my gen 3 camry.along with aftermarket 6.5's in my doors.i have a sweet 150 or 200 watt pioneer amp.i want to hook it up so im pushing some much needed wattage from my aftermarket speakers.the amp has speaker level input so i know i can use this amp for that.my question is : what type of amp kit i should purchase,gauge,wattage all that stuff.im not very electronically inclined,and i know you guys are.OR instead of pushing the speakers with the amp,i have a 200 watt 8 inch woofer in a box already.should i use the amp for my aftermarket speakers in my car or the woofer???also are their any diy's on the site for doing all this.maybe i can do it myself and learn it once and for all.thanx guys ahead of timeeee
TheGhostCamry is offline   Reply With Quote
Old 11-22-2005, 10:25 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Is the Pionner amp 150W or 200W RMS? Do you have the model number of the amp?
For power: 8AWG should be ok, and 4AWG will definitely work.
Some good amp kits found here: http://www.knukonceptz.com
2007 Camry 2.4L 5M
Old 11-22-2005, 10:47 PM   #3 (permalink)
NOT too sure,the model number is gm-102 its a pioneer and its a bridgeable amp.does that help big guy?
Old 11-22-2005, 11:13 PM   #4 (permalink)
cam2Xrunner's Avatar
8 gauge is all you need.
If you want to use this 4 channel amp(it is a 4 ch right?) to power the sub too, use the front channels on the front speakers, then bridge the rear channels for the sub(That is if the sub's ohm configuration is doable-what ohm is the sub?)
