Line Output Converter help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2005, 05:04 PM   #1 (permalink)
View DELLTUNDRA's Photo Gallery
Can someone tell me whats the best way to install a Line Output Converter to my 2005 tundra with the JBL system? im trying to add an amp and 2 subs to my truck. thanks
DELLTUNDRA is offline   Reply With Quote
Old 11-28-2005, 04:46 PM   #2 (permalink)
Whats a Noobian?
sq_camry's Avatar
View sq_camry's Photo Gallery
goes inbetween the factory reciever and the amp
sq_camry is offline   Reply With Quote
Old 11-28-2005, 05:48 PM   #3 (permalink)
bigloubumpin's Avatar
Gameroom cash: $151645
View bigloubumpin's Photo Gallery
dont the JBL system have a amp already?
bigloubumpin is offline   Reply With Quote
Old 11-29-2005, 09:46 AM   #4 (permalink)
View drell42's Photo Gallery
Canada
you canstill do this, alot of amps have a high level input built in, if you buy an amp that has one built in you are set, if not you have to buy 1. they go for about $50CND. To hok it up all you do is bump a signle from your rear speakers. Just strip away a little insulation solder on some lines and you are done! you you use an external converter it should be grounded. Thats it.
Rick
drell42 is offline   Reply With Quote
