alarm install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2006, 03:49 AM   #1 (permalink)
zeb
View zeb's Photo Gallery
alarm install
I am putting in an alarm in my truck. It has a standard tranny so what i was wondering was, would it be better to put the starter cut relay on the ignition coil or the neutral start switch. I only ask because lets face it put it in gear and push and off you go without using the starter.
zeb is offline   Reply With Quote
Old 01-06-2006, 10:36 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
You're not adding a remote start, so having the starter kill relay with the starter wires is all you need. You could add extra cut-off circuitry to the ignition or fuel. Unless you mean you're adding a remote start, then I'd suggest look for one that will handle a standard/manual transmission.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 01-07-2006, 10:16 AM   #3 (permalink)
zeb
i guess i'm just looking for something different. i decided to set the alarm for normaly open and hid relays for the coil, starter and the nutreal start switch. i would love to see some one start it without the remote.
Help w/ alarm install, +12V Park Light Tap mandyfig Camry & Solara Lounge 1 08-08-2005 06:43 AM
Prestige alarm install help - 2000 corolla ve huntr24td Audio, Video, and Security - Tech 2 08-25-2004 03:46 PM
Alarm install on a 92 Camry, V6 maneesh Audio, Video, and Security - Tech 7 06-29-2004 02:55 PM
Alarm Install yrmac Audio, Video, and Security - Tech 7 08-08-2003 06:19 AM
