Stereo instal in a 2002 Camry w/ JBL - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2006, 10:21 AM   #1 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
What do I need to do a stereo install in a 2002 Camry with JBL system?
I have the stereo with a regular, non-jbl, wiring harness attached to it. So somehow I will need to bypass the JBL amp which is behind the glvoe compartment, correect?
I will be using the stock speakers in the car...I *THINK* that they are 2 ohm but I don't have the car here so I cannot verify. Anyone know if this is correct?
If they are 2 ohm speakers, will the amp in the HU have a problem with this? I think most HUs are designed to work with 4 ohm speakers.
I know I will need a dash kit, but do I need the metal sleeve around the stereo also or does it ISO mount using metal brackets that screw in like on my 2000 Camry?
2007 Camry 2.4L 5M
Old 01-16-2006, 10:42 AM   #2 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
if you run 2 ohms on a 4 ohm HU, the HU will most likely overheat.
WhiteRabbit is offline   Reply With Quote
Old 01-16-2006, 02:02 PM   #3 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
AH HA!!.. so thats why my h/u did that!.. i just thought it was a piece.. good thing i dont have the h/u anymore anyways
anyways. i forgot how that thing acctually sits in there.. but i think i used the brackets that came with the cars stock setup.. so it would sit in there just the same.. but like i said i dont remember what i did.. although it was the 01.. oo btw.. if yours isnt JBL then it wont be 2ohms they will be 4ohms
Corollacrazy42 is offline   Reply With Quote
Again: which cd/tape players fit 2002 Camry undrcroft Audio, Video, and Security - Tech 4 07-28-2007 01:18 PM
Gen 5.5 Factory Stereo sasair 5th & 6th Generation (2002-2006 & 2007-2011) 9 11-24-2005 04:34 PM
2002 V6 Camry won’t idle after battery change\cleaning of terminals. RenoJim 5th & 6th Generation (2002-2006 & 2007-2011) 0 08-18-2005 07:13 PM
JBL Premium from 01 Highlander to 04 Camry WWLCCP Audio, Video, and Security - Tech 1 07-10-2004 02:15 AM
Stereo Upgrade for 2002 Camry LE V6 2002Camry Audio, Video, and Security - Tech 0 03-04-2004 08:34 PM
