Depending on how much current will be running out of the 5V point, you can use resistors to create a simple voltage divider network. Use this formula:
Vout = Vin * (R2/(R1+R2))
Make sure you use resistors with proper wattage, otherwise, they will burn out.
But it's always best to use an IC that does DC-DC regulation.
Do not use CAT5 as that's meant for low-voltage, twisted-pair, high-speed communication cabling. You're just asking for troubles if it melts from the current draw though the 24-26 gauge wires.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
