98 avalon stock subwoofer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2006, 05:59 AM   #1 (permalink)
View ickstasy's Photo Gallery
as i posted before i was thinking of installing 2 12" subwoofers in my 98 avalon. however i saw what looked like a stock subwoofer behind the rear seats but still in the main cabin. located right under the rear windshield. does anyone know what size this is and how it sounds after being replaced with a better aftermarket subwoofer. also could i run it from my stock deck if i installed an amp to power it? how would the sound quality be? any input helps.
ickstasy is offline   Reply With Quote
Old 01-24-2006, 07:07 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $510425
I would guess it's an 8 or 10. You can run aftermarket subs with the stock head unit. You will need line-out converter or an amp with high or speaker level inputs. Then hook those to the rear speakers.
2007 Camry 2.4L 5M
Old 01-24-2006, 10:50 PM   #3 (permalink)
lZl jody lZl's Avatar
View lZl jody lZl's Photo Gallery
you can push a sub with a factory head unit but why would you want to? it would be like feeding an elephant tic tacs.
lZl jody lZl is offline   Reply With Quote
Old 01-25-2006, 12:29 AM   #4 (permalink)
He only wants the signal from the stock HU.
could i run it [a subwoofer] from my stock deck if i installed an amp to power it?
2007 Camry 2.4L 5M
Old 01-25-2006, 09:53 AM   #5 (permalink)
ewps. my bad.
Old 01-25-2006, 10:17 PM   #6 (permalink)
View HTxdragon's Photo Gallery
doing the same thing. but looking for one 10inch or 12 inch.
edit: not really i got a aftermarket headunit.
HTxdragon is offline   Reply With Quote
Old 01-28-2006, 12:23 PM   #7 (permalink)
Luc
View Luc's Photo Gallery
The factory sub is an 8", but the mounting is very particular. You can't simply drop another brand in, especially if it's not free air type. The OEM amp doesn't have enough power to drive anything besides the OEM sub.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
'98 Avalon dash removal ricerrx7 Introduce Yourself Here 1 01-11-2006 02:00 AM
98 Avalon Maintenance Jaggrey 1st Generation (1995-1999) 9 01-05-2006 08:55 PM
Drain for Radiator on 98 Avalon vairpack77 1st Generation (1995-1999) 3 11-19-2005 11:50 PM
98 Camry LE stock alarm ToyotaCamry98LE Audio, Video, and Security - Tech 0 03-17-2005 01:20 AM
97 Avalon stock sub parimento1 Audio, Video, and Security - Tech 4 02-18-2005 07:14 PM
