Testing Pre- amp outputs?!?!?!?!??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2006, 08:24 AM   #1 (permalink)
View Mrwho2's Photo Gallery
i was wondering how i could go about testing the pre amp outputs on the back of the head unit to see if they are putting out a signal?
Mrwho2 is offline   Reply With Quote
Old 01-24-2006, 12:40 PM   #2 (permalink)
View JLTD's Photo Gallery
You'll need a CD with a sinewave and a VOM that can read AC voltage.
JLTD is offline   Reply With Quote
Old 01-24-2006, 01:53 PM   #3 (permalink)
A VOM that reads ac voltage is no problem, but im not sure about the cd with sinewave, what exaclty is that, and where can i get it.? And then how do i do the test?
Old 01-24-2006, 02:25 PM   #4 (permalink)
cam2Xrunner's Avatar
http://www.realmofexcursion.com/downloads.htm
Old 01-24-2006, 02:44 PM   #5 (permalink)
thank you very much for the sinewave files. Now what do i do...? my guess is that i play the sinewave through my head unit then use my VOM on AC voltage to see if there is any voltage? shoudl there be a spec specifically for my face or is there a general a/c voltage for all outputs?
Old 01-24-2006, 02:59 PM   #6 (permalink)
What kind of headunit?
Old 01-24-2006, 03:15 PM   #7 (permalink)
My head unit is a kenwood im not sure of the model buit i can find out once i get a free momment at work
Old 01-24-2006, 03:26 PM   #8 (permalink)
Kenwood
Old 01-24-2006, 04:00 PM   #9 (permalink)
Should do somewhere between 0.1-2 volts.
Do you have an amp? Are you trying to rule out a possibility for no sound?
Old 01-24-2006, 11:41 PM   #10 (permalink)
I will be doing this test tomm. on my lunch break. i have 2 amps, a 2 channel 400w pyramid and a 4 channel 400w Boss. The boss is brand new. Both amps get the power lights on but niether put out to the subs. I am trying to see if my HU that is like 1 month old has output
Old 01-28-2006, 05:19 PM   #11 (permalink)
Whats a Noobian?
sq_camry's Avatar
View sq_camry's Photo Gallery
wow, i didnt know they had that, thanks for the linkage.
sq_camry is offline   Reply With Quote
Is it possible to hook up subs to a HU that doesn't have sub outputs? strmagiceet Audio, Video, and Security - Tech 7 06-01-2005 11:39 AM
stock scion xB head unit, rca outputs or no? killer xB Lounge 4 09-13-2004 09:46 AM
testin to see if my pic work PowerByBuddha Camry & Solara Lounge 12 04-20-2002 07:00 PM
testin [sPooN] aE86 Archived Corolla threads 15 08-25-2001 10:47 PM
