well i hooked the tweeters i bought from cam2xrunner to my amp and there's this annoying weeeeeeeeeeeeee sound comming out of it when the RPM goes higher it gets louder... i had my sub hooked up to the amp and it was working fine no weird noises or anything it's a 4 channel amp running in 4 channel mode cep nothing was hoooked up to the 2 of the channel now i hook the tweeters to it it makes that sound... what's going on !!!! i'm confused
are you runing your power wire next to your RCAs
if so that may be the problem
i had the same sound but never moved my RCAs to test it before i tolk my system out
but i was told that is what makes that sound
^That could be one reason for it. Also try grounding your amp to the same grounding spot as the sub amp. Another place to check is the Headunit ground. You might want to try grounding the headunit chassis and wiring that to the same grounding point as the amps too.
it's a 4 channel amp it was grounded to somewhere in the trunk but i'll try moving it around to a better spot for grounding... left side of the car has the power,rear RCA running to the amp..right side has RCA for the tweeters running along with the wires for the tweeters so may be that's it but i'll try some better ground wires
I'd be willing to place money on it being a grounding issue.
However, if it actually is something with the RCA or wiring in any way, try re-wiring, or upgradingot shielded RCAs or twisted speaker wire. I have my wires running every which way criss crossing, etc... and no whine or extra noise what so ever.
Originally Posted by cam2Xrunner
With a bangin sound system, Carputer with online connection, 1+ lateral G's, and a Twizler Dispenser. That's pimp right there.
I'd rewire it so that ALL power wire (including remote turn on) is on one side, and the signal cables (RCAs and speaker wires) are on the other. I've done testing on my noisy stereo, and even the remote turn on wire can introduce noise into the system.
