two amp setup - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2006, 07:40 PM   #1 (permalink)
View v-feezy11's Photo Gallery
two amp setup
Hi I was wondering if this is the correct way to set up two amps. Also, is 8 gauge enough for 350 rms on the sub amp? Please let me know if there is anything wrong with the diagram. Thank you.
http://img205.imageshack.us/img205/8...mpsetup5bb.jpg
v-feezy11 is offline   Reply With Quote
Old 01-30-2006, 09:36 PM   #2 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
use 4g all around
don't forget the RCA cables
and if you can, try to ground both amps on the same grounding point.
the fuse from the dis block to the amp really isn't necessary
lucanhookup is offline   Reply With Quote
Old 01-30-2006, 10:22 PM   #3 (permalink)
cam2Xrunner's Avatar
4 gauge to dual 8 gauge is perfect for your setup. Get a distribution block with built in fuse holders.
Everything looks good to me.
Do try to ground your amps in the same spot if possible, but if you don't have any noise problem with different grounding points it shouldn't matter too much.
Old 01-31-2006, 12:36 AM   #4 (permalink)
my profile amp for the sub says that 4 gauge is the right size. it puts out 350 rms. Could 8 gauge be used?
Old 01-31-2006, 10:33 AM   #5 (permalink)
Yeah 8 gauge is enough for 350 watts rms.
Old 01-31-2006, 04:42 PM   #6 (permalink)
View thoughthard's Photo Gallery
Overkill with 4 gauge now. Easier to run one the 4 gauge now, instead of installing the 8 gauge, removing it, and running the 4 gauge. Waste of money to buy the 8 gauge, and then having to buy 4 gauge later.
When I installed a Soundstream Reference 300 in my trunk, I ran 4 gauge, since the amp could accept 4 gauge wire, and to cover future upgrades.
T'd off the 4 gauge via a Stinger T block, is a Punch 60. Soundstream was replaced with a Kicker DX350. 647 watts total with no problems.
thoughthard is offline   Reply With Quote
Old 01-31-2006, 08:51 PM   #7 (permalink)
View Kevpalf's Photo Gallery
thats how i had mine set up but now i'm changing my 8 gauge to 4 gauge
Kevpalf is offline   Reply With Quote
Old 01-31-2006, 09:16 PM   #8 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $231380
iTrader Score: 37 reviews
View Knailgun's Photo Gallery
4awg my advice, you can always break it down with blocks, less headache in the future
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 01-31-2006, 09:24 PM   #9 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
ive got two different grounding points and no noise problems. i could have sworn i read somewhere to not use the same point....that's why i have two...
edit: i think i did it to shorten the grounds as much as possible
WhiteRabbit is offline   Reply With Quote
Old 02-01-2006, 04:27 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Not all amps have built on fuses.
My 2 amps don't, so I have to fuse them externally. A power distribution fuse block works nicely for this.
"Skoolin' the unlearned!"
Old 02-01-2006, 09:26 PM   #11 (permalink)
can I do a one 4 gauge in and two 4 gauge out and not use inline fuse? i think one 4 in and two 4 out would be easier. how would that setup work? thanx
Need recommendation on amp and setup (kinda long) OriNLboy Audio, Video, and Security - Tech 8 11-18-2005 06:40 PM
94 Cam Sub Amp Setup Wetbo310 Audio, Video, and Security - Tech 1 09-15-2003 11:09 PM
Amp required for this setup. gqdabien Audio, Video, and Security - Tech 14 11-06-2002 05:52 PM
