viper 791 alram installation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2006, 06:04 PM   #1 (permalink)
BigDaddyMike
View bigdaddymike745's Photo Gallery
Gen5 viper 791 alram installation
hey guys i just bought the viper 791 alarm for my car and was wondering if anyone has the whiering diagram for the installation. if anyone knows how to install alarms with remote start, please let me kno. I live in socal and am looking if someone can do it for me. also want to kno how much it should cost me professionally
Click to check it out. Its Sick
http://www.cardomain.com/ride/805128
bigdaddymike745 is offline   Reply With Quote
Old 02-27-2006, 06:07 PM   #2 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
i want to learn how to install alarms....
lucanhookup is offline   Reply With Quote
Old 03-01-2006, 12:52 PM   #3 (permalink)
BigDaddyMike
Gen5
anyone else with some help?
Old 03-01-2006, 03:57 PM   #4 (permalink)
View thoughthard's Photo Gallery
Getting the Viper Master sheet would be ideal. When a buddy installed my Viper 300ESP, that sheet told what and where.
Not sure if this will help...
Alarm...
Battery WHITE/RED (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/RED (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger RED/BLACK (-) 22 PIN CONNECTOR AT BCM TO THE LEFT OF THE FUSE BOX PIN 3
Domelight Super USE DRIVERS LATCH WIRE
LF Latch RED/GREEN (-) 12 PIN CONNECTOR IN THE DRIVERS KICK
RF Latch RED/GREEN (-) 22 PIN CONNECTOR AT BCM TO THE LEFT OF THE FUSE BOX PIN 11
LR Latch RED/WHITE (-) 20 PIN CONNECTOR ON THE FRONT OF THE FUSE BOX PIN 7
RR Latch RED/WHITE (-) 20 PIN CONNECTOR ON THE FRONT OF THE FUSE BOX PIN 7
Trunk Trigger GREEN (-) 12 PIN CONNECTOR AT BCM TO THE LEFT OF THE FUSE BOX PIN 6
Alarm Disarm DISARMS WITH UNLOCK (NOTE: A SINGLE PULSE WILL DISARM WITHOUT UNLOCKING THE DOORS)
Alarm Arm ARMS WITH LOCK
Parking Lights GREEN (+) 20 PIN CONNECTOR ON THE FRONT OF THE FUSE BOX PIN 19
Low Crr Pk Lights RED (-) AT STEERING COLUMN 17 PIN CONNECTOR PIN 14
Remote Start...
Ignition 2 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
Accessory 1 BLUE/RED (+) IGNITION SWITCH HARNESS
Starter 2 BLACK/WHITE (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE (-) AT STEERING COLUMN IN A 2 PIN CONNECTOR
Tachometer BLACK/ORANGE (AC) 4 CYLINDER 35 PIN AT ECM PIN 1, 6 CYLINDER 31 PIN AT ECM PIN 5
Speed Sense VIOLET/WHITE (AC) AT ECM BEHIND GLOVE BOX 35 PIN CONNECTOR PIN 17 OR 8
Low Crr. Pk Lights RED (-) AT STEERING COLUMN 17 PIN CONNECTOR PIN 14
Brake Lights GREEN/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED/BLACK (+) BEHIND GLOVE BOX GRAY 11 PIN CONNECTOR PIN 2
Horn GREEN/BLACK (-) AT STEERING COLUMN HARNESS (NOTE: ALSO IN A 24 PIN CONNECTOR ON FRONT OF FUSE BOX PIN 22)
Don't ask me to decode that though
thoughthard is offline   Reply With Quote
Old 03-01-2006, 03:59 PM   #5 (permalink)
Contact Paseo15psi. He could pry help you out more than I can.
Old 03-01-2006, 04:33 PM   #6 (permalink)
Str8 booming
View 99camrypimp's Photo Gallery
if u follow da directions and have a power probe to check and make sure that ur doing it right so dat u dont burn out the brain i did it in my gen 4 took me about 4hrs and an extra 2 because i forgot to program it like a genius so i was having idling problems and my sensors that i put all over the car werent working like i wanted them to but now everything is crispy in my car so patience is the best advice because if the gen 5 and gen 4 were made the same off the same wires, then most of the wires are colored coordinated if anythin pm me
99camrypimp is offline   Reply With Quote
Old 06-30-2006, 01:21 AM   #7 (permalink)
View te's02p11g's Photo Gallery
Hey bigdaddymike... how far did you get on that install? Can you shed some light... I am just about to do the install myself on the exact same car and alarm. Anything you have will help me! stright from the H1 harness to the auto start. Thank you!!
te's02p11g is offline   Reply With Quote
Old 07-02-2006, 02:06 PM   #8 (permalink)
Has anyone done a camry install with the Viper791xv?! I need to ask some questions to make I have the wires correct! Thanks
Turbo installation for 3SFE, what I got so far almc2242 Hardcore Tech and Competition 6 02-01-2005 09:06 PM
99 Camry: Viper Alarm Installation TiziteFoSheezy Audio, Video, and Security - Tech 23 01-22-2005 09:28 PM
