Help With Subwoofers Setup !!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2006, 10:27 PM   #1 (permalink)
Camryologist
ptycamry's Avatar
View ptycamry's Photo Gallery
4th Generation Help With Subwoofers Setup !!!
OK.. Here goes the story...
I just got a JL Audio subwoofer.. It is a 10", W3, Dual Voice Coil, 2 ohm nominal impedance.. 300W RMS...
I'm planning to get another one just like that one...
What should I look on an amplifier for those 2 woofers...??
How do I wire them..??
If I run the woofers in a 4 ohm setup, will that decrease my RMS power...??? Remember my woofers are 2 ohm nominal impedance...
Thanks for all the help...
ptycamry is offline   Reply With Quote
Old 03-11-2006, 11:40 PM   #2 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
honiestly there are alot of ways to wire. Mono amplifier and a mulit channel also depends on the power of your amp. I'm not a super expert but I would reccomend something around 300RMS and over. i'm running a Rockford Amp on audiobahn subs @ 2 ohms and my RMS is only around 150 and it dosent pound hard So I would use smthn powerfull to blast those two.
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Old 03-12-2006, 12:13 AM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Wire the two voice coils on teh sub in series, and then wire the two subs in parallel. This will have a net load of 2 ohms.
Wire them like this:
Then use an amp like this one:
http://www.arcaudio.com/arc-05/amplifiers/kar_9001.htm
2007 Camry 2.4L 5M
What Gasket for my setup u think. Trueno90Deuce Archived Corolla threads 15 01-17-2006 09:01 AM
Camry Sub Setup Pics Grayguy Audio, Video, and Security - Tech 38 11-18-2005 12:04 AM
Icthing to do suspension setup Wraith Hardcore Tech and Competition 5 02-22-2004 08:13 PM
Raising the efficiency of your turbo setup AngryAE101 Archived Corolla threads 4 12-22-2003 11:07 AM
Gen 4 Eibach Solara/Camry spring setup. cheeba Solara 0 10-24-2003 09:11 AM
