4" components are designed for mid to high feq responce. Make sure the speakers are in phase 1st. Fade your stereo to the front then balance side to side. If you hear more mid bass when you balance side to then you have a speaker out of phase. This can also happen front to back. Also, check to see if you have the cross-over wired correctly. It happens to the best of us. Try powering the speakers with a 50 RMS watt amp. Set the Amp to HFP (high feq pass) and the listen to the sound.
Now, they are 4" components. They will not put out that much bass. you should be able to fit a 5.25" in the door and a 6.5 in the rear deck if you try. Look at the basket of the speaker. (metal part around back of cone and voice coil) see if it will clear opening and if it will allow the window to move up and down.
If you want bass NOT sub-bass try a sealed 8" woofer in the trunk with an amp. Look to a Basoka tube (poor speller). If Bumps you want purchase a Ported box with a port feq of 35 hz or 38 hz a little high but if you like rock it will work, rap set it from 28 - 35. NEVER SET A SUBWOOFER to a feq above about 80 hz. 100hz if you are doing a PA. It just makes the subwoofer humm. And the sound is poor.
We sell the Alpine Type-R at the car audio shop I work at. It sounds great with the right amount of power and a clean sounding amp, Alpine, Clarion, Xtent, Mb Quart, Eclipse, JBL. About 50 - 100 watts RMS.
