Thanks!
I read your post on a total install. Great info!
For now, I have sitting on a pair of Tacotunes 6 1/2" adapters so I am good there.
I basicly have the same setup, just with crappy speakers. I am using a stock headunit (soon to go), through the amp with the rear channels bridged to a 6" bazooka tube. It's really about the speakers at this point...
Should I just switch out the mid/bass and tweeter using the stock crossover (easy) or should I change that out with the crossover that comes with the new components and where should I mount the new crossover? Pros and Cons to each?
Is there any value to those cup shaped foam speaker baffles that you sandwich between the speaker flange and the mounting surface?
http://www.crutchfield.com/S-5a1iSvl...ffle&i=237XT65
What power rating should I be looking for in a speaker system, given that my amp puts out 100w per channel. Should I go a little over or should I stay right on the max power of the amp? 100w amp + 100 max RMS Speaker?
I think it's an Alpine TR240?
I plan on deadening the doors, but what about the rest? I may be able to do the floor and rear wall (reg cab), but the firewall, roof, and floor in front of the seat will be a PAIN! Which parts are most important?
