-Looking for 97 Camry coaxial speaker advice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2006, 05:01 PM   #1 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
4th Generation -Looking for 97 Camry coaxial speaker advice
I currently have a 1997 Toyota Camry LE, it has the stock 6.5 coaxials in front and 6x9 coaxials in rear. I tend to listen to r&b, rap, techno, trance, and all that bass stuff. I would say I'm looking for SQ over SPL. Budget is roughly around $400 or so for front and rear and a amp, will probably add a sub and monoamp later.
I'm thinking to get a 6.5 coaxial for front and 6x9 coaxial for rear, and a 2-chn amp and have my HU power my rear speakers.
As for the coaxials, I'm not sure to go with 2-way or 3-way speakers, I think I'll go with the 3-ways. Is it okay to have 2-ways in front and 3-ways in back? Or vice-versa? (Remember, this is still coaxials)
For the 6.5s, I've been looking some Infinity Kappa 63.7i, the JL VR's, and heard things about the Pioneer REVs. Also some say the Diamond M361i's are a good idea. Any idea on which I should get?
As for the 6x9s, the JL VRs or TRs seem good, but I'm not sure if I should mix 3-ways with 2-way speakers, since VRs are 2-way while TRs are 3-way.
Any suggestion on what amp I should use to power the front two speakers? I looked at the JL e2150s, but some say the Memphis 16-MC150s are a better choice.
Sorry if I'm asking for a lot, just looking for suggestions on a first time setup.
I'm either considering to go for front and rear Kappas or probably front and rear JLs, any other recommendations?
Edit: The reason I'm not going with comps, is because it'll be a bigger hassle to mod up the front pillars for a tweeter and all.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 03-17-2006, 06:10 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Weird, I thought all Gen 4 Camry have tweets in the sail panel (the panel near the door mirror).
Anyways...check out the offerings at http://www.exilecaraudio.com/
They are a new company formed by engineers from Phoenix Gold. You may need to buy direct from them if they don't have a distributor in your area.
If you want coaxials, maybe check out these speakers:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5866248849
2 Channel amp recomendation
http://edesignaudio.com/product.php?...pid=24&cur=USD
2007 Camry 2.4L 5M
Old 03-17-2006, 06:51 PM   #3 (permalink)
2GR FTW
darksparkz's Avatar
What are the differences between a coaxial and braxial speaker set? Other then the obvious price differences?
Nahh, i would hope that there are tweeters, but there aren't. Maybe it was only in the XLE ones with some preminum audio option.
Old 03-17-2006, 07:56 PM   #4 (permalink)
The difference is mostly the way that the tweeter is placed and aimed as far as I can tell, but the braxial setup is said to produce better sound than coaxial speakers.
CDT makes high grade or audiophile grade speakers. They also come with crossovers which the Kappas do not include. The Kappas probably only have some high pass filters to prevent the tweets from producing low frequencies but does nothing to prevent the woofer from producing the higher frequencies.
My 2000 Camry has tweeters in the door but that was the standard stereo system. Maybe it was a change for Gen 4.5.
2007 Camry 2.4L 5M
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
5th Gen Camry Speaker ? BLAZETIGER Camry & Solara Lounge 2 04-03-2005 06:36 PM
What size speaker in 2005 Camry LE?!?! Cyberhwk Audio, Video, and Security - Tech 6 01-27-2005 08:46 AM
99 Camry door panels / speaker replacement JayVee Camry & Solara Lounge 5 10-08-2004 07:53 PM
