polk MMC6500 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2006, 04:28 AM   #1 (permalink)
BigDaddyMike
View bigdaddymike745's Photo Gallery
Gen5 polk MMC6500
im gettting a set of these components. they are 125RMS. i want to kno what would be the best amount of wattage from the amp? would 200Watts from the amp fry the speakers? what would happen if they are underpowered?
Click to check it out. Its Sick
http://www.cardomain.com/ride/805128
bigdaddymike745 is offline   Reply With Quote
Old 03-19-2006, 05:01 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
For $350, go with CDT components instead.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5854231335
If your amp puts out 200W, you should either turn down the gains or risk damaging the speakers especially if the signal becomes clipped. With too little power, the output will be less volume or not as clear at higher volumes if you turn it up to where it clips. You can't really underpower them though, you probably could drive those speakers with a stock HU if you so desired.
2007 Camry 2.4L 5M
Old 03-19-2006, 11:51 AM   #3 (permalink)
BigDaddyMike
i can get these components for 130
Old 03-19-2006, 11:53 AM   #4 (permalink)
If you have such a hookup, get these:
http://www.polkaudio.com/caraudio/products/sr6500/
2007 Camry 2.4L 5M
Old 03-20-2006, 12:44 AM   #5 (permalink)
BigDaddyMike
i can get those for a lil over 300. i dont think i wanna spend that much money into my car
Old 03-20-2006, 01:07 AM   #6 (permalink)
Frugle's Avatar
View Frugle's Photo Gallery
technically, volume doesn't = power right? turning down the gain doesn't turn down the watts being sent to it.
please correct me if I am wrong .
If you send more power to it, you do have a much greater chance of blowing them.. I do not believe sending 200 to 125 watt speakers will hurt them.. but it might.. it is always better to get an amp that sends out the proper RMS for your speakers.
also, is it a 200 watt RMS amp? if its a wallmart 4 channel 800 watt amp.... then no, your not going to be sending any more than 60 RMS MAYBE..
Frugle is offline   Reply With Quote
Old 03-20-2006, 02:01 AM   #7 (permalink)
For $130, I think you might be better off with Elemental Designs 6000s instead.
http://www.edesignaudio.com/product....pid=28&cur=USD
2007 Camry 2.4L 5M
Old 03-20-2006, 02:47 AM   #8 (permalink)
BigDaddyMike
what kind of amp should i use in powering my new components? would it be foolish of gettina cheap amp? should i go with certain brands? how much should an amp cost me. im thinking it should be 300RMS 2 channel amp? right? something around there
Old 03-20-2006, 08:18 AM   #9 (permalink)
Del The Funky One
Delay_FTB's Avatar
View Delay_FTB's Photo Gallery
Search around on here. As far as brands go, Cam2Xrunner put together a pretty thurough list of what's what in the car audio realm. Cost depends on brand/quality really. Best way to do it is probably E-bay.
Originally Posted by cam2Xrunner
With a bangin sound system, Carputer with online connection, 1+ lateral G's, and a Twizler Dispenser. That's pimp right there.
Delay_FTB is offline   Reply With Quote
Old 03-21-2006, 11:07 PM   #10 (permalink)
BigDaddyMike
Gen5
hey guys im looking at ebay for an amp to power my components. the components are rated at 125rms. i am thinking of buying the MTX 4202amp. it is 100 x 2 but the thing that worries me is that it says that its 100 x 2 into a 2Ohm load. what does that mean. whats the difference between 2 ohm and 4 ohm. and how are my components gonna be wired
Old 03-21-2006, 11:54 PM   #11 (permalink)
cam2Xrunner's Avatar
If the amp says it does that power at 2 ohms then you will see half that power if you have 4 ohm speakers.
Old 03-21-2006, 11:56 PM   #12 (permalink)
You can get those for around 300?!?! That is soooo worth it for that price.
What other brands do you have hookups on? Maybe then it will help to rec. some amps.
Old 03-22-2006, 01:22 AM   #13 (permalink)
BigDaddyMike
Gen5
now all i have hookups for is polk audio. i use to have hook ups on infinity and im waititng for my connections for eclipse. can u recomend a nice amp that will power around 100 wats to each speaker rms wattage that is 4ohm.
Old 03-22-2006, 06:04 PM   #14 (permalink)
BigDaddyMike
so what kind of amp do i need?
it has to be 100W x 2 at 4OHM load?
100W x 2 at 2Ohms wont work?
Old 03-22-2006, 06:53 PM   #15 (permalink)
If the amp puts out 100W x 2 @ 2 Ohms, it'll still work, but it only puts out half as much power @ 4 ohms, which the Polk speakers are.
If you plan on getting Polk Momo components, and you have hookups on Polk amps, get the 4 channel amp. Use two channels @ 150W for the components, and then bridge the two other channels for a sub.
2007 Camry 2.4L 5M
Polk bigdaddymike745 Audio, Video, and Security - Tech 2 03-18-2006 03:11 AM
Polk audio components Bruce Campbell Audio, Video, and Security - Tech 5 11-18-2005 10:59 PM
Polk C300.2 2 Channel Amp ??? WhiteRabbit Audio, Video, and Security - Tech 13 07-20-2005 05:21 PM
FS: Polk Speakers for Tacoma cjinchi Audio, Video, and Security - Tech 0 05-15-2005 01:06 PM
