Well hello! I just got myself a new used 03 Camry recently.. I converted from my Ford Taurus which keeping it working per month is twice a car payment.. so I figured I needed a toyota or honda, and toyota it was....
Did a search, found a couple of threads that sort of helped me, but they didn't answer my question completely.
anyways, I am not a fan of atermarket head units.. I know this sounds weird.. but I don't like using them, I like the way the stock units work, and look.
In my taurus, It came with a stock JBL sound system, with a 6x9 sub... so all I had to do, is buy a reverse adapter for the sub, run that into a line level converter, then run RCAs to the amp.
easy to do... I ran a 4 gauge power wire into my trunk to power it all, and then I spliced into my auto antenna to get the on/off line. (a constant 12 volts is what keeps the antena up.. so as long as the antenna was up, there was the 12 volts to turn the amp on as well)
so now I would like to do the same in my Camry. I have an 03 SE with the 24 valve V6.
it has the "JBL" sound system, but no sub in the trunk... so I have a few questions.
1) turn on lead.. how should I do that? is there a fuse or something i can run a line from to the trunk to get it to turn on?
2) where do I pull the signal? can I just splice into one of the speaker wires, and attach that to a line level converter?
3) will that make that speaker less loud?
4) this is kind of a stupid question, those are 25 watt speakers, can I run a 3rd wire from the splice and run that into the amp for the turn on lead?
5) I will be buying a whole new wireing kit to use, what system do you recomend to do this? I hear a lot about "the big three" or something like that.. what is that?
6) are the tweeters in the front already highpass filtered?
7) I will have some more questions later!
Thanks! the Taurus Car Club of America (
www.taurusclub.com ) has been a huge help to me for my taurus, and I really hope this place can be one too!
