Getting my amp to turn off with my stock head unit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2006, 11:42 AM   #1 (permalink)
The Walking Carpet
View Waterwookiee's Photo Gallery
How would I go about getting my amp to turn off with my stock head unit? I have it wired to the ignition now, because there is no remote lead out of the back of a 05 Taco stock unit. My only need to change the stock unit is becuase the amp stays on all the time and makes this hiss through the speakers while driving (with the radio off).
If there is a way to have the amp turn off at the same time as the radio, that would solve my head unit problem.....
I have heard of people putting the remote lead to a fuse or something???
Thanks all!
2005 base model, Silver Streak
Behold, Dori the "Wonder Taco"
Waterwookiee is offline   Reply With Quote
Old 03-21-2006, 12:55 PM   #2 (permalink)
View JLTD's Photo Gallery
Setting the amplifier input sensitivity correctly will go a long way toward reducing noise floor in general.
You can get an amp that has signal sensing turn on and it will behave the way you want it to.
JLTD is offline   Reply With Quote
Old 03-21-2006, 01:16 PM   #3 (permalink)
cam2Xrunner's Avatar
Thanks all!
What color wire are you connecting the amps turn on lead to?
Old 03-21-2006, 02:53 PM   #4 (permalink)
The Walking Carpet
I was told when I first hooked all this up, that the ignition wire (I don't remember the color (orange mabye?) was the only one that would work. So when I turn the truck on, the amp comes on, and when the truck is off (but the key is still in the acc post.) the amp in on, but if I turn the key to off, the amp goes off with the rest of the electiral.
Old 03-21-2006, 03:04 PM   #5 (permalink)
Make sure the amps turn on wire is connected to the thin grey wire on the back of the headunit.
Old 03-22-2006, 12:12 AM   #6 (permalink)
Go Camry, Go
madmax_cam's Avatar
View madmax_cam's Photo Gallery
3rd Generation
here is a complete tech sheet on your truck.
It depends on if it is 2dr, 4dr, or ext, and if it is a true 05 or a 06,so here is all .
05 2dr
BatteryBLUE/YELLOW(+)RADIO HARNESSAccesoryGRAY(+)RADIO HARNESSGroundBROWN(-)RADIO HARNESSIlluminationGREEN(+)RADIO HARNESSLF Speaker (+)PINKLF Speaker (-)VIOLETRF Speaker (+)LIGHT GREENRF Speaker (-)BLUERadio SecurityYES
05 4dr
WIRECOLORPOLARITYLOCATIONBatteryBLUE/YELLOW(+)RADIO HARNESSAccesoryGRAY(+)RADIO HARNESSGroundBROWN(-)RADIO HARNESSIlluminationGREEN(+)RADIO HARNESSLF Speaker (+)PINKLF Speaker (-)VIOLETRF Speaker (+)LIGHT GREENRF Speaker (-)BLUELR Speaker (+)BLACKLR Speaker (-)YELLOWRR Speaker (+)REDRR Speaker (-)WHITERadio SecurityYES
05 ext
add a fuse to the wire at the point you tap on to it incase you NEED it. :-P
It's car audio why not do it!
95 V6 XLE on TSW w/ Yokohama treads
2 x sets Infinity Kappa Perfects 6.5 comp, 2x Infinity Kappa Perfect 12 DVQ, Ported box @ 2.25 cuft, w/ port fequency @ 29.5, 2x Swiss Audio Digtal Amps 2200 watts of fun, 1x 1 Farad Cap
madmax_cam is offline   Reply With Quote
Old 03-22-2006, 12:51 AM   #7 (permalink)
View david in germany's Photo Gallery
Looking at the harness from the back you need to connect with the #8 pin point
(this pic is missing the wire but this is the one you need.)
I believe the #7 is the power antenna pin so inless you want the amp to turn off when the radio is off (cd or casette is on) don't use #9 If you are also using a stock amp then the connection will be on the stock amp and not the radio.
David
I am in my own little world but it's ok they know me here!
david in germany is offline   Reply With Quote
Old 03-22-2006, 09:14 AM   #8 (permalink)
The Walking Carpet
WOW! Thanks everyone. I will pull it out and give it a shot....
Old 03-22-2006, 09:25 AM   #9 (permalink)
The Walking Carpet
Here's another question.
Is it possible to add a wire to a harness? Can I get one of those little clips that jam a wire in the plastic plug in the #8 slot should I find that I don't have a wire lead there?
Old 03-22-2006, 09:40 AM   #10 (permalink)
All you have to do is splice into the thin grey wire from the back of the headunit.
Old 03-22-2006, 01:00 PM   #11 (permalink)
Yes, If you are missing the wire you can stich a new terminal in.
Can I "I-pod" the toyota stock unit? No cd changer controls.... mofrogeek 2nd Generation (2005+) 8 12-05-2005 08:43 PM
stock head unit play mp3? Marty McFly 2nd Generation (2005+) 5 11-22-2005 01:25 AM
03 Sienna w/JBL - can you use aftermarket player with stock amp angelob Audio, Video, and Security - Tech 7 04-21-2005 01:13 PM
Aftermarket Install - Sienna Stock Amp - Some Q's Eye8Pussies Audio, Video, and Security - Tech 9 01-31-2005 12:27 PM
Speaker, Head Unit, & Amp Install (03 corolla) gmagne2 Audio, Video, and Security - Tech 3 10-10-2002 04:07 PM
